-   -   cure time (http://www.diychatroom.com/f4/cure-time-161064/)
hidden1 10-24-2012 07:56 PM
cure time
152 Attachment(s)
i will be finishing up a aggregate sealing job .Is clean and dry but wanted to know if it will be ok as to dry/cure time before rain.I will be sealing it around 9 am and high will be 81 for day low humidity ..later around midnight some showers into next day..temps from then on will be 50s for long time.
Should 8-12 hours with 6 in full sun be enough before late night then early morning rain?
chrisn 10-25-2012 04:06 AM
What does the can say? If you already did it, not much you can do about it now:whistling2:
Gymschu 10-25-2012 07:45 AM
Personally, with any coating on any surface, I like to at least have 24 hours without moisture hitting the new coating.
hidden1 10-25-2012 04:29 PM
152 Attachment(s)
ok thanks..i went ahead and did all but small last area. would like to try and get it in early morning but afraid it will be too close to a shower in late afternoon.It says 24hrs dry time.does the high winds and 75- 80 degree temps help with drying it faster ?
Gymschu 10-25-2012 10:24 PM
It will dry MUCH faster with wind and heat, sometimes too fast.
chrisn 10-26-2012 06:32 AM
DRY time is much different than Cure time, ( just for hidden's information)
Mr. Paint 10-26-2012 05:00 PM
Most Tech Data Sheets advise not to paint 24 - 48 hours in front of rain. The paint will withstand rain, however, depending on weather conditions, it won't be fully cured for 4 - 6 weeks on average. During that time frane, the film is considered 'tender' and if anything can happen it's probably going to be bad...:(
smalpierre 10-26-2012 08:22 PM
FYI - Sherwin Williams has a lifetime paint that's formulated for cold weather / close to rain conditions - Resilience. You can paint 1 hour before rain hits and be ok in most conditions, or paint in as cold as 35 deg. temps if I remember correctly.
chrisn 10-27-2012 04:38 AM
Originally Posted by smalpierre (Post 1038590)
FYI - Sherwin Williams has a lifetime paint:eek: that's formulated for cold weather / close to rain conditions - Resilience. You can paint 1 hour before rain hits and be ok in most conditions, or paint in as cold as 35 deg. temps if I remember correctly.
:laughing::laughing:
Mr. Paint 10-29-2012 11:43 AM
While it is true that a 100% Acrylic Product will form a film in cold temperatures (35-38F) it still has to go through a curing cycle. If S-W works for you, then excellent; just be sure that there isn't too much 'fine print' on the label making it a marketing ploy.:)
