Crown Moulding Painting - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2007, 09:09 PM   #1
crown moulding painting
Just completed putting up crown and trim moulding. Both were preprimed pine. I have gone around and put wood filler in all the nail holes, but have not caulk the scarf joints or the inside coners.
The wood filler used was MiniWax stainable wood filler.
I have two types of caulk, a couple of tubes of Tremco Thermaflex 834 and a few tubes of Apex Plus. I have used both in the past and to a non-pro they both seem fine, is one better than the other?
Also, I plan to prime, and paint the moulding after a light sanding. I think I heard that you prime before caulking? Is that true?
Lastly, you think I will need two coats?
The primer is Ben Moore All Purpose Primer and the paint is Pitt's Manor Hall semi-gloss brillant white.
Thanks for the help?
WorkOnIt
WorkOnIt is offline   Reply With Quote
Old 06-17-2007, 09:25 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by WorkOnIt View Post
...Tremco Thermaflex 834 and a few tubes of Apex Plus. I have used both in the past and to a non-pro they both seem fine, is one better than the other?
I'm not familiar with either
Make sure they are paint-able caulks
And there may a "XX year guaranty" that will give you a general indication of quality
Yes
You should do any priming before caulking
One, it give the caulk something to hold on to
Two, you can't sand caulk
Lastly, you think I will need two coats?...the paint is Pitt's Manor Hall semi-gloss brillant white
Probably
You may 'get away' with one for actual coverage
But you'll get much better protection and looks from two
Especially with the shinier paints
Sometime the gloss doesn't quite cover in thin spots etc. and you get flashing (sheen changes)
Two coats would eliminate that
slickshift is offline   Reply With Quote
Old 06-17-2007, 10:09 PM   #3
Home Improvement Guy
ron schenker's Avatar
I think it's Alex Plus
ron schenker is offline   Reply With Quote
Old 06-18-2007, 10:56 AM   #4
made in U.S.A.
Hamilton's Avatar
Here is Alex : I prefer this to Alex :
It's thicker and doesn't seem to shrink as much.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 06:51 PM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 09:05 PM
Painting crown molding greeniemom Painting 6 02-26-2008 02:26 PM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-14-2007 11:12 PM
