Originally Posted by chrisn
meaning?
amp I believe is the computer language term for ampersand, which is the & symbol. sometimes, if certain punctuation is missing or incorrect computer syntax is used, or a simple glitch occurs, the language behind the screen will appear as text. It could happen if the post was written in Word and pasted into this window, as different programs read things differently. Doubt that was the case but . . .
What you see below is the result of my taking punctuation out of the following language that creates the familiar quote box, instead the language is visible
[quote=chrisn;617752]meaning?
[quote]
[/quote
See the difference between the top and the bottom. If I add it back in it gives the following;
meaning?
That is what the upper right corner box is A/
A.
