Crown Molding Touch Up - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 10:22 AM   #1
Rewards Points: 208
i had my hardwood floors refinished and stained. we have white crown molding on the floor and it needs a little of touch up from the refinishing.
i have never painted in my life, and i don't know what's the technique to touching up white crown molding paint.
Scully is offline   Reply With Quote
Old 12-11-2011, 04:31 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
Find the exact can of paint used before, shake it up well, clean the baseboard well, let it dry. Go to paint store and buy a good brush,open paint can, dip brush into paint, brush offending spots.
Old 12-12-2011, 01:13 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Its it really crown molding on the floor?
titanoman is offline   Reply With Quote
Old 12-12-2011, 03:09 AM   #4
If you haven't done much painting, you may want to put painters tape down on the floor along the baseboards, as well put your paint can on cardboard or something similar.
If there are any holes then fill and sand before painting, if there are any gaps between the wall and baseboards, caulking along the wall will improve the look of it.
chrisBC is offline   Reply With Quote
Old 12-12-2011, 11:16 AM   #5
Rewards Points: 526
* baseboard moulding
Windows is offline   Reply With Quote
Old 12-12-2011, 10:07 PM   #6
Rewards Points: 208
sorry, i meant baseboard moulding. what would you use to clean the baseboard with prior to primer and paint? there's a little bit of hardwood floor stain on the baseboard.
Uploaded with ImageShack.us
Old 12-12-2011, 10:22 PM   #7
Disabled wood vet
titanoman's Avatar
Looks nice in there.
Sent from a Samsung Galaxy S2
Old 12-13-2011, 03:19 AM   #8
chrisn's Avatar
Rewards Points: 496
Clean with Dirtex
Old 12-13-2011, 11:18 PM   #9
Originally Posted by Scully View Post
i had my hardwood floors refinished and stained. we have white crown molding on the floor and it needs a little of touch up paint from the refinishing.
Use small strokes and don't put a lot of paint on the brush or it'll drip all over the place.
blingthing is offline   Reply With Quote
Old 12-14-2011, 06:20 AM   #10
Rewards Points: 208
should i sand first?
what type (or grit) sand paper should i get?
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
making own crown molding marin001 Carpentry 7 03-28-2010 11:08 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
