Crown Molding Paint Finish - Painting - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 07:50 PM   #1
I have recently had wood crown molding installed in my dining room. I am getting mixed opinions on what type of paint finish to use. We painted the walls with a flat finish and the very experienced elderly owner of the paint store strongly recommended a flat finish for the crown molding. All of my friends, many of them self proclaimed decorators tell me that I should only use semi gloss. Need your help! Thanks.
Desperate Housewife is offline   Reply With Quote
Old 11-10-2008, 08:12 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Well, just to mix it up a little, I'm going to recommend a nice enamel in a "satin" finish
(honestly, over the last few years, most high end painting companies have been doing way more satin finish then semi-gloss on trim, doors, and cabinets...including crown molding)
slickshift is offline   Reply With Quote
Old 11-10-2008, 09:36 PM   #3
Workaholic's Avatar
Satin is good, I will recommend semi-gloss. Really sheen comes down to a matter of preference. Flat is rarely done around me and i think it looks kind of cheap but that is just my opinon.
Sean
Workaholic is offline   Reply With Quote
Old 11-11-2008, 01:16 PM   #4
Rewards Points: 506
I use full gloss, but Sherwin's ProClassic seems to run a little flatter than most other brands. However, given the amount of grime your average window, doorframe or door can accumulate, I can't imagine using flat, as it probably won't hold up as well to scrubbing.
I know you are painting crown, but if it were my house, I would want the crown to match the rest of the trim.
SirWired
sirwired is offline   Reply With Quote
Old 11-12-2008, 09:26 PM   #5
Kellster
mjkpainting's Avatar
Rewards Points: 77
I would look at the sheen of the other trim in the room and match the crown molding to the rest of that trim.
Flat= no sheen- hides imperfections
Semi gloss- sheen and will accent the trim
Most people prefer a semi gloss for doors and trim.
mjkpainting is offline   Reply With Quote
Old 11-13-2008, 12:04 AM   #6
The fact that you had the crown molding installed tells me that you'd like it to be noticed, yes? Do no paint anything that you want to be noticed in flat finish. Use a semigloss sheen and enjoy.
casselli is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 11:38 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 08:13 PM
