Crown Molding & Chair Rail - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 09:56 PM   #1
Crown molding & chair rail
How do you experts paint crown molding & chair rail that has that thin detail on the bottom diving into the wall. I end up painting the bottoms with the wall paint to get it looking decent. I heard that is called the California cut and that is not acceptable in high end work.
dyier is offline   Reply With Quote
Old 01-15-2008, 02:54 PM   #2
Can you post a photo?
redline is offline   Reply With Quote
Old 01-15-2008, 06:49 PM   #3
Pro Painter
Acceptable or not is up to the owner. In my opinion, it's not acceptable.
However, my opinion is also that real wood crown moulding would not be painted to begin with.
If it's your house and you like it, go with it.
joewho is offline   Reply With Quote
Old 01-15-2008, 07:38 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by dyier View Post
How do you experts paint crown molding & chair rail that has that thin detail on the bottom diving into the wall...
A 1" or 1.5" brush depending
slickshift is offline   Reply With Quote
Old 01-16-2008, 01:22 PM   #5
Workaholic's Avatar
Yep true enough, thats why there is so much mdf used these days because it is going to be painted.
Sean
Workaholic is offline   Reply With Quote
Old 01-16-2008, 02:51 PM   #6
Rewards Points: 506
Personally, I like the way it looks on crown. Our handyman offered a choice with our pre-primed MDF crown, and painted two sections of crown to let us pick.
Certainly the fact that it is easier is a plus, but I like the way it looks also.
I don't do it to base, chair, or casings, just my thin-lipped crown.
SirWired
sirwired is offline   Reply With Quote
Old 01-26-2008, 11:13 PM   #7
Chair Rail as Crown molding?
Need some molding around bathroom ceiling to hide some imperfections and separate marble walls from drywall ceiling, but don't want anything large & loud. Can Chair Rail look Ok as crown molding? Any suggestions?
laytons is offline   Reply With Quote
Old 01-27-2008, 08:05 AM   #8
Rewards Points: 506
There are some pretty basic crown moldings available. My old house had crown that was just a 2" curve with a lip on each end. I suppose you could also try to use a simple door/window casing. Since chair rail "bulges", I don't see the ledge that would produce next to your ceiling as looking real good.
SirWired
Old 01-30-2008, 01:50 PM   #9
Painting contractor
Whenever we install crown in a bathroom we always make sure to prime the back of the crown to protect against moisture. This is best for all crown but not necessary where there is no moisture. Most big box store moldings don't come with the backs primed. Then we make sure to use a good paintable siliconized caulk at the top edge, the bottom edge and the joints then two coats of a good quality topcoat. If the crown is already installed make sure to following the above caulking recommendations. LOL
Thepaintman is offline   Reply With Quote
Old 01-30-2008, 09:21 PM   #10
Pro Painter
Chair rail is commonly used as crown moulding. It's mounted with the thin side facing down.
Crown molding termination at tile Stickboy Carpentry 4 12-26-2011 11:35 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Crown Molding: Lay flat or stand upside-down dtmbizzle Carpentry 15 09-27-2007 12:33 AM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 02:34 PM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 12:35 PM
