Crown Molding - Painting - DIY Chatroom Home Improvement Forum
Old 02-16-2008, 10:11 PM   #1
Crown Molding
Hey guys/gals -
I'm new to this site and I love what I've read so far.
I have some raw crown molding in my bedroom that I need to prime/paint/caulk, and I'm not sure about the best approach. Some say to prime first, then caulk, then paint....others say fill the holes, caulk, prime, paint....
Which is the right order?
Thanks!
Coop
CoopDaddy is offline   Reply With Quote
Old 02-16-2008, 10:24 PM   #2
Remodeler
MinConst's Avatar
This is probably a matter of both preference and color.
If you have white ceilings, and white crown I would caulk the ceiling joint after painting if the colors are different then caulk first. Either way there should be a minimum amount of caulk. Very fine cut on the tube. Fill and sand all nail holes and corners prior to painting
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 02-16-2008, 10:40 PM   #3
Painter's caulk is great for the joint lines between the molding and the ceiling and the molding and the wall but not so good for nail holes and cracks as it shrinks when it's drying, leaving a visible depression. Use a good nail hole filler or non-shrinking spackle on the nail holes and imperfections.
End Grain is offline   Reply With Quote
Old 02-17-2008, 09:00 AM   #4
remodeling pro
Prime the moulding on the ground, and sand it before hanging. Then caulk and spackle, spot prime any splices or outside corners that may have been "massaged" with sandpaper on installation and show raw wood, sand the new primer and spackling, then finish paint.
troubleseeker is offline   Reply With Quote
Old 02-17-2008, 09:01 AM   #5
Darylh's Avatar
It's hard to spot all the little holes and imperfections on raw wood so I give the wood a sanding, vacuum and tack cloth it off then prime. This will show all the imperfections. I then do all the filling first ( nail holes, dents and so on) then sand and clean and tack cloth. When I am happy with that I then do my Crown to ceiling, crown to wall caulking using painters caulk. The idea here with caulking is to just use enough to fill the voids between the crown and the surface. Use a damp cloth the wipe the excess of the wall and just your finger or tool on the ceiling. You don't want to remove any of the texture so a damp cloth is not recommended.
Darylh is offline   Reply With Quote
Old 02-20-2008, 02:33 PM   #6
Pro Painter
Proper procedure is to prime first, then fill and caulk, if painting.
If staining then stain and finish, then fill holes with color matched putty.
It's fairly common though, to fill holes on raw wood before priming/painting.
Always paint the caulk. Caulk yellows and it's counterproductive to use a long lasting paint while the caulk turns colors in a year or two.
joewho is offline   Reply With Quote
Old 02-21-2008, 12:32 PM   #7
In my experience i've always fill nails holes, then prime and paint. This is no necessary the right way to install crown moulding, you can also prime the material before installing, or even prime, paint, and then install, filling the nail holes last. It all depend on your situation.
___________________
home decorating ideas
rk_king2004 is offline   Reply With Quote
Old 02-24-2008, 03:08 PM   #8
She'sapainter
since it sounds like it's already mounted I personally would
1. get blue tape and mask off top and bottem of CM apply tape 1/8 inch away from CM sound time consuming but trust me it's not.
2.Get acrylic paintable caulk and apply it where the CM and tape meet with a damp rag wipe access caulk off with some pressure continue steps 1 and 2 where the CM will go.
3. after about 20 min prim and paint remove tape right after last coat while paint is still wet pulling the tape not down or out but back so your not pulling the paint away from wall.
Ive been painting 25 years and I always fine ways to cut corners this one works every time .
you can also use this same method in corners where new colors are used
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
Installing Crown Molding fmolden Carpentry 6 01-08-2008 10:09 AM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 07:13 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 01:34 PM
