Crazy Crazing Paint -- Help! - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 10:33 AM   #16
Rewards Points: 394
Glidden is box store crap paint with a parent company in Holland or something. Akzo Nobel, actually.
Buy paint from a paint store.
Actually, the Duo is a very good product (39% volume solids, it is a premium)- it is not an economy or commercial grade of paint. The Gripper is fine for the prime coat. If there is a thick application, poor air flow, this can cause sagging or cracking. I agree with Ric's sollution to correct this.
Will22 is offline   Reply With Quote
Old 05-02-2012, 10:43 AM   #17
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Originally Posted by sdsester View Post
Glidden is box store crap paint ...Buy paintr from a paint store.
Oh really?
I had never heard the issue of different temperatures and possible paint problems. I wonder if that was the problem I had when I used Glidden Gripper. Put the primer up late summer [warm], brought the paint out of the [cool] basement and used it. Cool paint, warm wall = problem?
hyunelan2 is offline   Reply With Quote
Old 05-02-2012, 11:07 AM   #18
Rewards Points: 394
ICI Dulux Stores are now Glidden Professional Stores.
Old 05-02-2012, 11:50 AM   #19
Rewards Points: 386
Originally Posted by hyunelan2 View Post
Oh really?
Hiya hyunelan...
In my earlier post, I probably should've explained things a little better than I did...Cool product, warm walls can certainly contribute to the problem of crazing - relatively rare for it to occur over a prime film that has had ample curing time, but it can happen. What's probably more common (and this is the part I left out) is if a prime coat, or two, is applied to a surface - and cooler temps set in during those critical first few hours of curing - the coating can feel dry to touch, and it'd make sense to continue with the finish application after waiting the necessary time as described on the label. Unfortunately, in this scenario, the film hasn't cured enough to be impervious to the solvents (water & glycol) of that newly applied finish. If the prime coat, which has had some interruption to curing, absorbs some of finish product's vehicle into it's film, the prime coat will then expand - Meanwhile, the solvents from the finish coat begins flashing off as they're supposed to, and the finish film constricts. Therefore, expanding prime film + constricting finish film = crazing.
Most people know that latex paints shrink as they dry - brush out some latex on a sheet of notebook paper and observe. In the example of crazing, this dynamic won't change - the prime coat doesn't have to expand much (microscopically) for the crazing to occur. Crazing won't happen as often with lesser quality flat paints 'cause the film is so perforated by the pigments (unless the paint is applied way too heavy). It's usually more apt to be noticed in higher sheened or higher quality products.
I hope this hasn't confused anybody...sometimes my lack of articulation comes off as non-sensical ranting.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
hyunelan2 (05-02-2012)
Old 05-02-2012, 03:50 PM   #20
Learning Things Every Day
Jay 78's Avatar
I like Glidden Paint.
Oh really?
What, you guys don't drink the "if it's not SW or BM it's total garbage" Kool-Aid?
Under Construction
Jay 78 is offline   Reply With Quote
Old 05-02-2012, 10:10 PM   #21
ric, your theory might make sense in this case. When I applied the primer, it was over two hot, dry days, about 80 degrees. The next day it rained and then, uh, snowed (Utah spring is weird as hell) and two days later when I applied the top coat it was only about 65 degrees.
The only thing that doesn't make sense is that I waited two days before applying the top coat over the primer. That should have been enough time to cure, but maybe with the temperature swing it wasn't.
In any case, as the top coat has set, the crazing is less noticeable (it never really cracked, just crazed), and it was never very thick (I apply reasonably thin coats) so I think I can probably get away with sanding it lightly in a few days.
Thanks very much for the help.
tiredofpainting is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
