Craftsman Pressure Washer 6.5hp - Painting - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 03:28 PM   #1
Craftsman pressure washer 6.5hp
It starts but runs for a few minutes and shuts down. It restarts and runs couple of minutes and shuts down
Plunge is offline   Reply With Quote
Old 06-06-2011, 03:52 PM   #2
Gymschu's Avatar
Rewards Points: 1,022
Spark Plug? Filter dirty? That's what I would check first. Also, some PW's have low oil shutdown features so you may be low on oil & it's shutting down automatically.
Old 06-06-2011, 04:12 PM   #3
Sounds like a fuel issue.... Check the fuel filter and air filters first. If it's old gas, dump it and put new gas in too. Give the carb a good squirt with a carb cleaner too, especially if it's been sitting for a while with the old gas in it.
Good Luck
cnda17 is offline   Reply With Quote
Old 06-06-2011, 07:20 PM   #4
Too Short? Cut it Again!
Check the inbound water filter too. If there is insufficient water flow the machine will stop. The water is on when you start it right? Not being insulting but sometimes we forget the little things.
Pressure washer not producing pressure rocks911 Tools 1 05-09-2011 06:38 PM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 08:16 PM
Craftsman Pressure Washer Won't Start mark2741 Landscaping & Lawn Care 12 11-07-2009 08:25 PM
excell pressure washer help ericsloan Tools 1 06-14-2008 02:39 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 05:44 PM
