Old 11-04-2009, 12:57 PM   #1
Default Cracked drywall at joint near door?
So I have an outside joint coming together and the drywall has a few holes where the joint is coming up at a couple places. Would the right fix be to just use joint compound to fill the holes and sand it down? Or should I put some sort of backer on it (eg: joint tape or the mesh drywall tape)?
Pic is attached.
The holes are small so just not sure what the best way to handle it would be.
ClemsonJeeper is offline   Reply With Quote
Old 11-04-2009, 01:59 PM   #2
ccarlisle's Avatar
If that's a metal corner piece, I'd make sure that it is screwed back in properly, using drywall scres into the holes that run up and down the piece. Chip away till you find some. Then all-purpose drywall compound, primed and repainted.
ccarlisle is offline   Reply With Quote
Old 11-04-2009, 06:12 PM   #3
Drywall contractor
Nails tend to work better for fastening metal bead than screws, but most people are used to using screws. Just make sure to pull the screws up flush with the edge of the bead. You'll likely pull more of the bead loose trying to get it pulled tight, but just keep going until no more mud cracks loose. As stated above, chip out ALL loose mud. A setting type compound would be best for at least the first fill coat to reduce "shrinkage" and number of coats. But if this is the only repair you have, probably not worth buying a bag. Ready mix will work fine, just need additional coat(s).......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-05-2009, 01:01 AM   #4
Painting Company, NY
Clean out the crack and coat it with durabond, flush with the surface. Then when that dries put a piece of mesh tape over the crack about 2 inches longer than the crack on. C each end. Coat the tape with a 4-6 inch knife with ready mixed compound. When it dries recoat with a wider knife, like a 10 inch. Sand, prime, and paint.
Painting Contractor, NY
www.kelloggspainting.com
housepaintingny is offline   Reply With Quote
Old 11-06-2009, 04:25 PM   #5
I ended up doing what the ccarisle posted. I dug up a bit closer to the corner, found the holes and drywall screwed them in. This worked great - then I patched over the holes I made and just got done painting it. Looks great!
Thanks much.
Old 11-06-2009, 04:30 PM   #6
ccarlisle's Avatar
Great! Look I'm no pro with drywall or anything so I learned something too. The primer does a lot of the work in smoothing out the transition compound/drywall. Some people skip the primer...not a good idea.
Old 11-06-2009, 05:27 PM   #7
Is that door hard to latch? If so, I suspect the corner bead may crack mud again unless you fix the door, or you have children..... Little sticky round felts on the door stop where it hits first will help. Or adjust the strike plate by moving it out or tapping it open more with a chisel and hammer. If not a door/wall movement problem, the bead just wasn't nailed on enough. Then just move along folks, nothing to see here....
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
More On This Topic
Alright, this is a really great example of a different kind of texture. We started with that really light texture that we had in the other room, but we added some more mud to this- some plaster on the wall with a trowel to get this look that we wanted... Read More »
How to Apply Mosaic Grout
How to Apply Mosaic Grout by Expert Village
Okay, now this is a good consistency for the grout. You can see that it's pretty thick and now we're ready. Now you want to wear rubber gloves when you do this work because the grout can be a little bit harsh on your hands. And you want to have a sponge... Read More »
Applying Mosaic Grout
Applying Mosaic Grout by Expert Village
Okay, I've cleaned some of the grout off and I'm going ahead and start on the upper part. Let this set just a bit. The grout does get a little bit firmer and harder as time goes on. It begins to set. Just squash it in to all the crevices and all around... Read More »
After you decide what type of wire that you want to to make your wire jewelry, you need to decide your type of beads. I am someone who that I just choose the beads that grab my attention at the time. I have lots and lots of beads to choose from. You've... Read More »
A lot of times on marching snare sticks you would notice that the beads would chip or wear. Right here we got a bead that is completely cracked and totally unusable so putting it next to a good bead that is how different they are. Now a lot of times you... Read More »
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 05:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 01:23 PM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 09:45 PM
Pre Hung Door Issue! bmster Carpentry 8 03-11-2008 09:31 PM
Door jam between rooms is drywall dsanders55 Flooring 2 03-05-2008 07:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
