Covering Wood Grain - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 05:33 PM   #1
covering wood grain
I have removed several layers of paint from my kit kitchen cabinets. I sanded them, put 2 layers of Kill on them and 2 layers of paint. The wood grain continues to show through. Is there anyway to cover the grain so it looks smooth?
ssmith8667 is offline   Reply With Quote
Old 05-05-2013, 05:52 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
From your description they sound like oak cabinets. There really isn't a way short of skimming the surface with a filler like Sheetrock mud or
Jmayspaint is offline   Reply With Quote
Old 05-05-2013, 05:57 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
Or spackle, to totally hide the grain. Extra coats of pain will help. That's just the nature of oak.
Old 05-05-2013, 06:24 PM   #4
cdaniels's Avatar
FPE brushing putty will fill in and smooth the grain.Two coats sand after each coat,prime with oil primer then two coats of paint. http://www.finepaintsofeurope.com/st...p?idproduct=14
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
chrisn (05-06-2013), jsheridan (05-05-2013)
Old 05-05-2013, 07:31 PM   #5
Too Short? Cut it Again!
Melamine paint is thick enough a couple coats should fill in well sanded grain. It is not exactly fun to apply and while hard, it is prone to chipping. I don't think you can get it in but a fairly high gloss sheen either.
Old 05-06-2013, 02:33 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
Charlie daniels has the right approach
I would be leery of using jc and or spackle
also 2 coats of kill is over kill
Covering wood grain with paint Jim Cuthbertson Remodeling 3 07-11-2012 12:30 PM
Wood over Concrete Stairs? Need Some Knowledge From You Guys jousley Building & Construction 26 06-27-2012 09:38 AM
wood grain showing with trim paint job CheriAlli Painting 7 05-17-2012 08:34 AM
Covering stucco covered foam columns with wood Susan5 Carpentry 1 01-28-2011 09:28 AM
