Covering Water Damage - Painting - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 09:12 PM   #1
Covering water damage
I am painting a bedroom with minor water damage on the ceiling and walls. I'm going to use Sherwin Williams Duration, and need to know if Kilz primer is the way to go, or if the Muti Purpose Sherwiam Williams primer will be sufficient. Thanks in advance!
jettlash84 is offline   Reply With Quote
Old 12-08-2011, 11:04 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Depending how much and how bad-
Neither are made for sealing water damage.
The sure fire primer would be oil cover stain or shellac ( alcohol ) based BIN.
There are some waterborne ones that may do it, perhaps with 2 coats ( dry in between) - Zinsser 123, Z Smart Prime. others.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-09-2011, 06:38 AM   #3
It's very minimal, you have to be very close to even notice it. I'd like to use something water base if possible.
Old 12-09-2011, 07:12 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Smart prime will most likely do what you want, or 123
Old 12-09-2011, 12:32 PM   #5
ltd
Rewards Points: 536
you said it was very minor.first see if you can wash it off .if not do as brush jockey said. p/s for small spots you can use a spray can of bin or cover stain sherwin williams has their version of this
ltd is offline   Reply With Quote
Old 12-09-2011, 02:26 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Sherwin Williams Problock primer
housepaintingny is offline   Reply With Quote
Old 12-09-2011, 03:47 PM   #7
Gymschu's Avatar
Rewards Points: 838
I vote for the Cover Stain for this reason: It may look minor right now, but if you use a latex stain blocking primer you may reactivate the stains. The water in the latex lays on the surface & SOMETIMES wicks those stains back through the primer. Sometimes you luck out, but my experience has been to seal these stains with Cover Stain and be done with it.
Old 12-10-2011, 09:02 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
If it is just a small spot, a couple sprays from a spray can of BIN, Coverstain or Kilz will do the trick.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
