Covering Up Ink - Painting - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 10:20 AM   #1
Rewards Points: 109
Covering up ink
Ugh, so I made some marking on the walls where to put access panels in the ceiling and the ink keeps bleeding through. I am using Zinsser Bulleys 1-2-3 primer. Suggestions?
BimmerRacer is offline   Reply With Quote
Old 03-17-2010, 11:02 AM   #2
Kilz? I have no affiliation with the company below, just Googled Kilz and found a decent description. Says covers ink:
http://www.acehardwaresuperstore.com...37.html?ref=42
AxelF is offline   Reply With Quote
Old 03-17-2010, 11:14 AM   #3
Rewards Points: 109
yeah, I think I am going to pick up some killz 2 at HD today and give it a shot. Totally didn't think about what I was doing when I made the marks.
Old 03-17-2010, 01:00 PM   #4
Newbie Bill
Rewards Points: 520
I think there are some unsatisfactory results with the Kilz 2 product, but I'm just repeating what I have read here, no personal experience. I'd suggest you wait to hear what some of the painting experts suggest. I'm sure they will reply soon.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 03-17-2010, 07:48 PM   #5
jlhaslip's Avatar
Rewards Points: 1,564
shellac will stop the bleeding ink.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-17-2010, 08:06 PM   #6
Learning by Doing
Leah Frances's Avatar
Remove the ink. Use a variety of solvents start with ETOH, naphthalene spirits, mineral spirits, paint thinner, elbow grease, tar based soaps.
Prime and paint.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-17-2010, 11:09 PM   #7
Rewards Points: 512
Rubbing alcohol should remove the ink too. But maybe not if you've already painted over it.
gma2rjc is offline   Reply With Quote
Old 03-17-2010, 11:16 PM   #8
(the original)
Rewards Points: 756
Yep, nothing better. Sounds like it's just a few lines, so just pick up a spray can of Zinsser BIN. Next time, use a pencil
ratherbefishin' is offline   Reply With Quote
Old 03-18-2010, 10:26 AM   #9
Rewards Points: 109
I picked up a can of Kilz spray. Couple of light sprays and I can't see it no mo'
Has anyone used LSI vinyl floor covering? Famof7 Flooring 2 11-15-2009 02:42 AM
Outdoor Pergola with suntuff covering clodall Carpentry 1 07-12-2009 11:34 AM
best material for shop wall covering? will52100 Building & Construction 7 02-20-2009 10:14 PM
Covering cabinet underside - some help please SandyK Carpentry 5 02-01-2009 08:28 PM
Threshold covering dwlodyka Building & Construction 1 08-11-2008 02:53 PM
