Covering Lines In Wood Paneling. - Painting - DIY Chatroom Home Improvement Forum
Old 12-28-2012, 10:12 AM   #1
covering lines in wood paneling.
Hi.
Can you guys give me suggestions on how to fill the lines in painted wood paneling. Will spackle or mud work for this? Thanks
aj_diyer is offline   Reply With Quote
Old 12-28-2012, 03:41 PM   #2
cdaniels's Avatar
I have seen it done with mud but I don't think I would do it.I wouldn't trust it.How much paneling do you have? Have you thought about covering it with drywall?
cdaniels is offline   Reply With Quote
Old 12-28-2012, 04:09 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Did you look to see what the walls are like under the paneling?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 12-28-2012, 04:13 PM   #4
Rewards Points: 558
Its more trouble then its worth.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Gymschu (12-28-2012)
Old 12-28-2012, 06:20 PM   #5
I would prime the paneling with oil Cover Stain, then spackle (joint compound) the recesses. I just watched another guy do it on another part of a job I'm on. Looks good. I don't think you would have any problems with delamination.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 12-28-2012, 07:24 PM   #6
Gymschu's Avatar
Rewards Points: 170
I've done it several times over the years with mixed results. Epson is right, most of the time it's more trouble than it's worth. You fill the cracks, let dry, fill again until you get it flush. Then you have to sand and throw dust everywhere. It's a big process and in the end you still have paneling. I actually like leaving the lines. After painting, they blend in and aren't quite as noticeable. Follow JSheridan's process if you really want to fill them in. Another old trick which I don't recommend is covering the gaps with masking tape.
Gymschu is online now   Reply With Quote
Old 12-28-2012, 08:15 PM   #7
It is a lot of work. Couldn't you install a heavy wall liner and just paint that?
Old 12-29-2012, 03:16 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
http://www.flexiwall.com/pages/home_page.htm
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (12-29-2012), jsheridan (12-29-2012)
Old 02-08-2013, 02:06 PM   #9
Grants Painting's Avatar
I would just throw up new drywall. Seems like it would be more trouble than its worth to fill the cracks.
Grants Painting is offline   Reply With Quote
Old 02-08-2013, 06:39 PM   #10
cdaniels's Avatar
See what's under the paneling.I have run across a lot of houses with paneling over drywall.
Charlie Daniels painting and repair
The Following User Says Thank You to cdaniels For This Useful Post:
Grants Painting (02-08-2013)
Wood Paneling on Music Room StarStryker11 Interior Decorating 5 12-20-2012 09:35 PM
Zero VOC Primer to paint wood paneling geoduck Painting 4 12-16-2009 12:02 PM
uneven wood paneling joefromcal Carpentry 6 04-30-2009 10:50 PM
Different paint type for outdoor house wood paneling? gante Painting 10 03-23-2009 02:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
