Covering Drywall Swirls On A Ceiling - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 02:04 PM   #16
m1951mm's Avatar
If you do decide to paint it use a thick nap roller 3/4 or even a 1". One thing to remember about using rollers, it will take a few dips into the paint followed by light rolling to get paint worked into the nap of the roller. Do not run the roller dry!!!!!!! Keep it wet and do not press to hard to compress the nap on the roller. This IMHO is a perfect place to use a lambskin roller cover. Holds more paint and does not crush as easy as a synthetic cover.
I still would learn to love it.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-22-2011, 07:50 PM   #17
Gymschu's Avatar
Rewards Points: 936
The funny thing is, if you shortcut it by only doing one coat, the swirls can actually flash through your newly skimmed ceilings. So at least do 2 coats, and, yes, it may take THREE coats as Brushjockey said.
Gymschu is online now   Reply With Quote
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
How would I replace ceiling tiles with drywall on a ceiling with no studs? weedelf Drywall & Plaster 3 02-28-2011 11:43 PM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 12:52 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
