Coverage On Trim (with Brush) - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 07:33 PM   #1
MarginallyQualified
Rewards Points: 2,464
coverage on trim (with brush)
On aluminum facia, gutters, downspouts, and other such things...
after a good wash and rinse using TSP and brush...
the plan is to use an Acrylic Latex to paint much of what is currently white
(a rather dark brown and the rest a lighter contrasting brown shade).
What is a reasonable expectation for SqFt/gallon?
Old 02-10-2012, 09:43 PM   #2
jschaben
Rewards Points: 502
I just go by whats on the can for estimating, I use the smallest number for the first coat and the largest number for the second coat. I usually have to much though.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 02-10-2012, 09:46 PM   #3
Rewards Points: 14,026
What do you plan on using for paint? Brand name?
user1007 (02-10-2012)
Old 02-10-2012, 10:16 PM   #4
BraniksPainting's Avatar
I'd buy a gallon of each to start with. You can always have more mixed up.
BraniksPainting is offline   Reply With Quote
Old 02-10-2012, 10:48 PM   #5
Too Short? Cut it Again!
You are thinking of applying with a 2.5-3 inch, decent angled sash brush right?
Cost you $15-20/each retail. But ask for some discount where you are getting paint which is not at a box store right?
You were not in your wildest dreams thinking or dreaming of getting paint on with those 20/$5 bag of brush things box stores sell were you?
Thought not.
Old 02-11-2012, 09:25 AM   #6
A Little Of Everything
Rewards Points: 1,364
Just buy a gallon. It's only a couple dollars more than a quart, and you'd probably end up having to buy a second quart.
Your key to success on this job is not the brand of paint you buy, but using the right primer.
DrHicks is offline   Reply With Quote
Painting trim - so many brush marks! brons2 Painting 8 02-03-2012 04:06 AM
Techniques and tips EvilNCarnate Painting 5 01-11-2012 06:53 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Use a foam Brush to touch up some trim with an oil base paint? djtjak43 Painting 2 03-01-2009 03:49 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
