Countertop Paint - Painting - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 08:53 PM   #1
countertop paint
Has anyone used this product?
http://www.rustoleum.com/CBGProduct.asp?pid=447
I'm curious if it looks any good and how difficult it was to prep and apply. I can't imagine painting a countertop and it looking any good, but I've been wrong before
klinkster is offline   Reply With Quote
Old 08-29-2010, 11:58 PM   #2
jlhaslip's Avatar
Rewards Points: 2,098
I have yet to find any countertop paint that works for longer than about a year.
Save yourself the headache and replace the top now.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-30-2010, 05:42 AM   #3
There are a few things you can do. Finnaren and Haley make a polyurethane paint that we've had on our countertops for years. Insl-x makes something similar. Also, you can use venetian plaster. It's a little bit trickier, but you'll actually end up with stone countertops which can then be sealed.
drewpy is offline   Reply With Quote
Old 08-30-2010, 09:24 AM   #4
This product is a Alkyd product, which is brittle. A counter top takes a beating. Beating + Brittle= Bummer. As it has been posted, replace or use a polyurethane.
mark942 is offline   Reply With Quote
Old 08-30-2010, 11:05 AM   #5
Rewards Points: 558
For the headache of maintaining your newly painted counter top and the time you took to prep the counter for paint and masked off all other areas its just not worth it. Replace the counter and have another 10 – 20 years of enjoyment…
Note: just so you know about some don’ts on painted counters:
1) Don’t cut into it because you will chip the paint.
2) Don’t put hot pans on it or else you will melt the finish and have paint stick to your pan, wife wont like that one bit.
3) You have to clean up spills before they dry.
4) Don’t let water accumulate on the counter for long periods of time.
epson is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Countertop paint Tony Wadsworth General DIY Discussions 1 11-21-2009 04:52 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
