Could Anyone Recommend Steps To Insure A Professional Result - Painting - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 12:18 AM   #1
Could anyone recommend steps to insure a professional result
I am an amatuer painter with lots of experience, but have not used enamel paint in years. I am contemplating using a satin enamel paint on some beadboard I installed in a craft room, but am a bit unsure how difficult it will be to get a smooth durable finish. Could anyone recommend steps to insure a professional result?
chimayo gardens is offline   Reply With Quote
Old 04-30-2011, 04:13 AM   #2
An old Tradesmen
Rewards Points: 6,922
Made this its own thread.
Old 05-01-2011, 03:12 PM   #3
I am thinking of painting some beadboard I put in a craft room with cream colored enamel. It has been many years since I painted with enamel. Can anyone share tips to insure I get a professional looking result?Thanks for any help you can give me.
Old 05-01-2011, 03:53 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Reading does not necessarily give the skills- but here's the order of business:
Prime with underbody ( primer meant to go on raw wood before enamel)
sand, fill nail holes, caulk where needed
First finish coat
Lightly sand , second finish coat
I would back brush all. this means apply a section with a roller and finish off with long brush strokes to lay off smooth.
Would help to know what paint you wanted to use.
Oil / waterborne? Whose?
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
chimayo gardens (05-01-2011)
Old 05-01-2011, 11:43 PM   #5
painting with enamel paint
Thanks for the tips. I have not purchased or decided on the brand or type of paint yet. Any suggestions?
Old 05-02-2011, 05:11 AM   #6
I would suggest using a middle to higher grade satin/semi-gloss enamel by SW or BM, maybe BM Aura. The better paints by the top brands will cover better. Since painting bead board is time consuming, if you have to go to a third coat with a lesser paint, the labor outlay will dwarf the higher material cost.
Old 05-02-2011, 05:52 PM   #7
Painting Beadboard
Thanks for the suggestions, I usually do use either BM or PP, so I will try the Aura. I have already primed the board so will not be so time consuming for the finish coats. Do you recommend using a sealer on the finished wall?
Old 05-02-2011, 07:29 PM   #8
Don't really get the question. You mean over the enamel finish, put a clear coat? No.
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 08:32 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
Brick steps failing sk8z Building & Construction 10 03-28-2009 03:16 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
