Is This The Correct Order To Paint Kitchen Cabinets? - Painting - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 09:44 PM   #1
Rewards Points: 37
is this the correct order to paint kitchen cabinets?
Hi-
Going from finsished maple to antique white w/ glazing. I did this 4 years ago but can not exactly remember how I did it. All paints are water based. Looking for some input.
scrub down
sand with Orbital 180
clean/ 409
roll primer
lightly sand 220 by hand
spray primer
spray solid color
spray antique white
spray antique white
apply glazing
spray solid vinyl sealer
spray 2 coats of clear satin
sacseven is offline   Reply With Quote
Old 12-17-2012, 10:03 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Sorta-
Are you removing doors?
You roll primer- do you back brush or just leave the stipple?
Why 2 coats primer?
You say spray- Do you know how?
Usually one primer 2 top coats can get it.
What is the difference between vinyl sealer and clear coat?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-17-2012, 10:34 PM   #3
Rewards Points: 37
I do not know how to spray. I do one coat of primer myself because I never think enough primer gets on the cabinets when it is sprayed on. Its been my understanding that too much primer is a better problem than not enough.
My tenant is a painter and he will come and spray the cabinets.
I was hoping to find if there was a difference between vinyl sealer and clear coat.
Old 12-18-2012, 03:37 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
One (1) coat primer is all you need
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (02-09-2013)
Old 12-18-2012, 08:59 AM   #5
Rewards Points: 5,974
Painting maple cabinets.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Gymschu (02-09-2013), tylernt (12-18-2012)
Old 12-18-2012, 12:53 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Me too
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 02-08-2013, 02:46 PM   #7
Grants Painting's Avatar
No this is one situation that the two coats of primer will do well. Maple has alot of tannins that will want to soak through and make your white into a light yellow.
Grants Painting is offline   Reply With Quote
Old 02-08-2013, 06:18 PM   #8
chrisn's Avatar
Rewards Points: 232
really?
Old 02-08-2013, 06:36 PM   #9
cdaniels's Avatar
If you use the right primer one coat is always enough.Wrong primer and ten coats wont work.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
jsheridan (02-08-2013), ToolSeeker (02-08-2013)
Old 02-08-2013, 06:57 PM   #10
I wasn't aware of that, and thought otherwise. Where did you find that info?
Old 02-08-2013, 08:57 PM   #11
Ahhh. yes there are woods with more tannins. However not many so dark. How clever of you to point that out.
If you would pay attention to the original poster. (for the last time) He mentioned ALL products are water based. With that knowledge alone I figured they would do better with the extra coat of primer. Especially if it were to be sprayed on too thin. Remember guys were supposed to be here to help.
Is any of this making sense?
Old 02-09-2013, 07:00 AM   #12
chrisn's Avatar
Rewards Points: 232
[QUOTE=Grants Painting;1112767]Ahhh. yes there are woods with more tannins. However not many so dark. How clever of you to point that out.
Is any of this making sense?[/QUOTE]
not to me there are woods with more tannins , like oak, maple is not one of them
Old 02-09-2013, 09:21 AM   #13
Yes it has very little tannins. However the ones it has are VERY DARK. They will show through with a white finish with water based products.
Old 02-09-2013, 06:12 PM   #14
There's a lot of confusion on this short thread, between tannin content, latex primers, and the number of coats required, it's a wonder anyone has a straight answer. If OP hadn't already had his answer, we would need to clear through the haze.
Old 02-10-2013, 09:08 AM   #15
I must be lucky I have never had tannins in maple bleed thru any primer. To the OP if you feel better with 2 coats then go for it, it won't hurt anything.
Kitchen Cabinets - ready to assemble kind sbmfj Kitchen & Bath Remodeling 3 08-24-2012 06:02 AM
Your favorite paint for kitchen cabinets? Hazelnut3 Painting 17 08-17-2012 08:59 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
Painting Kitchen Cabinets (part 2) - Which Paint Gun/Sprayer? 1655graff Painting 5 10-05-2007 12:10 PM
