Corner Tape Coming Up, Do I Have To Pull All Down. - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 11:45 AM   #1
Corner Tape coming up, do i have to pull all down.
I'm attempting to paint a bedroom.
In one corner there is tape under the paint that has bubbled in one spot. Do I have to pull it all down and put a new piece of tape up.. or can i just pull off that two inch area and try to mud over it?
If I pull it all off should I try to put a new piece of tape up.. What is the purpose of the tape on the corners?
caseynshan2 is offline   Reply With Quote
Old 11-25-2011, 12:00 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Use a razor knife and cut it cleanly just past where it is loose. The tape is making a corner and usually is expanding over a little open space between the 2 surfaces. It would be best to reapply tape to this area.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Paint coming off wall when I pull masking down smythe01 Painting 10 01-25-2008 01:51 PM
tape and float - tape is coming off! samf Remodeling 3 09-29-2006 08:09 AM
