Copper Primer - Painting - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 06:26 PM   #1
Copper Primer
What primer will bond to copper?
Pinedezyne is offline   Reply With Quote
Old 07-24-2012, 07:52 PM   #2
Gymschu's Avatar
Rewards Points: 230
I'm sure there is something out there that works, but, the bigger question is why you would want to paint copper. I ask this question because the process of CLEANING the copper so it is ready for paint is a daunting task. I've never painted copper in my 33 years of being a painter. Sherwin-Williams would be the place to go for answers. I know they carry galvite which is a primer for galvanized metal so I'm sure they have a product for copper.
Old 07-24-2012, 08:06 PM   #3
Paint Pro
Yes
sherwin-williams sells a self-crosslinking latex primer called pro-cryl, it will bond to the copper. then topcoat with a product called bond-plex. another self-cross linking polymer with extremely aggressive adhesion. prep the copper with a denatured alcohol wipe-down.
Expert Paint is offline   Reply With Quote
Old 07-24-2012, 08:13 PM   #4
Too Short? Cut it Again!
I was only asked to paint copper a time or two in all the years. Once it made sense I guess as the client wanted copper radiator pipes finished. The other time was for chimney flashing and gutters and I scratched my head as to why anyone would pay for copper flashing and gutters and then want them painted? Client is always right though!
As Gymschu suggests, cleaning and etching the copper to take a primer was the hardest part and I was warned to skimp would end in disaster with adhesion being blocked and the copper oxidizing through every thing on up through the finish coats. I am a obsessed and compulsive when it comes to prep so this did not bother me so much but I remember the fumes given off. Make sure you have adequate ventilation and even I wore gloves for this part of things.
Once cleaned, I applied a self-etching metal primer as commonly used in the autobody industry. Rattle cans worked great for the radiator pipes but liquid was needed for the gutters. I do not remember if this was the brand or not but the packaging was industrial looking.
I used rattle cans for the radiator finish coats too---heat resistant engine enamel as I remember. I honestly do not remember what I used for the flashing and gutters but it was probably an oil-based product as this was some time ago. I should think any modern bonding acrylic product would adhere to the primer? Best to check though.
I guess the projects worked out as I was never called back to fix anything.
Obviously if you are painting copper pipes, you may have heat or condensation issues to consider in picking your finish coat. Again, ask at a real paint store.
Old 09-20-2015, 06:44 PM   #5
Rewards Points: 2
Painting copper
I"m an artist and planning to ad paint to my sculptures, in small parts.
I got concerns that aggressive primer will eat trough thin sheet copper.
But because most of my works are exterior i"m afraid to use the latex based.
cherkasski is offline   Reply With Quote
Old 09-20-2015, 08:16 PM   #6
Rewards Points: 2,906
I don't see why an ordinary alkyd primer wouldn't stick well to copper.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
copper clad aluminum CopperClad Electrical 45 06-23-2012 04:21 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
