Old 08-25-2011, 02:04 PM   #1
Concrete patio paint
I have a concrete patio that was painted by formr owner.
The paint is coming up and looks bad.
The concrete is a brom finish/texture and the patio is covered.
What should I do?
Power wash dry repaint?
wire brush the whole ting then paint?
Can I use the epoxy garage floor stuff?
bjlffire is offline   Reply With Quote
Old 08-25-2011, 08:39 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
remove as much of the existing coating as you can by scraping and pressure washing. allow the concrete to dry for at least 24 hours and apply 2 coats of solvent stain. do not use epoxy coatings in direct sunlight or it will chalk and amber rapidly.
mustangmike3789 is offline   Reply With Quote
Old 08-25-2011, 11:26 PM   #3
Pressure washer to remove the paint. Then stain the concrete if desired.
____________
Vince
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Repairing crumbled end of concrete patio spaceman spif Building & Construction 1 08-10-2011 12:34 AM
Concrete Patio with brick ribbons vactek Building & Construction 4 04-11-2010 11:10 PM
Ideas for deck over concrete patio and beyond-pics- bdobs Building & Construction 6 05-10-2009 09:58 PM
