Old 09-28-2011, 09:08 AM   #1
concrete paint
I want to paint my exposed basement (concrete) foundation with a durable concrete paint. I used DRYLOC masonry paint before but it is really gritty, thick, and hard to apply. I am looking for a concrete paint similar to what you see at inground pools or by the street department to paint curbs. Any suggestions?
jrocket15 is offline   Reply With Quote
Old 09-28-2011, 04:09 PM   #2
Gymschu's Avatar
concrete paint
If it's exposed then I am assuming it's ABOVE GRADE.............in that case you can paint with a latex paint of your choice, whether Satin or Semi-gloss in the color of your liking........no need for DRYLOCK which seals block on the INSIDE of the basement. If I misunderstood and you are applying something to exposed block BELOW GRADE that will later be backfilled, you need thoroseal which is a concrete based waterproofing that has to be mixed with water and goes on rather thick.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
