Concrete Floor Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 01:47 PM   #1
I have always used oil-based enamel to paint concrete floors - long lasting, durable - and so I am late to facing the ban...
I would appreciate the next best paint solution, suggestions, brands or is there any state still selling? I am in NY. Need a large quantity, covering about 10,000 SF industrial, commercial space.
Thank you!
ty67 is offline   Reply With Quote
Old 05-22-2012, 02:07 PM   #2
Rewards Points: 386
Thank you!
ty..
Concerning the ban...there is no ban. Oil based paints are available in the state of NY. Some manufacturers have decided not to provide alkyd products, made to the specific VOC regs that NY allows, but other manufacturers have... especially so if your application is in an industrial environment. If alkyd (oil) is what you really want, check with your local INDEPENDENT paint dealer for a regional paint manufacturer that still manufacturers alkyd products for the OTC states.
...But since you're talking to your local INDEPENDENT paint dealer anyway, ask him/her what their recommendation is for painting a 10K sq.ft. industrial floor with. After asking you a bunch of questions, you may be surprised to find that alkyd is not gonna be their first recommendation. Good luck to you.
ric knows paint is offline   Reply With Quote
Old 05-22-2012, 03:04 PM   #3
Too Short? Cut it Again!
As a waterbased product I have had great results with Benjamin Moore's Floor, Porch and Patio paint (not sure I remember the name exactly). It is an acrylic product reinforced with epoxy and flows on nicely. It is self priming.
I to always leaned toward alkyd floor paints but I am not sure I could claim them superior to the reinforced acrylics, silicones, epoxy paints and other stuff out there now. I happen to think that we have other more dangerous sources of VOCs than paint but you know, if we can use products low in them I am all for it.
As suggested, there is probably a commercial or industrial coating grade of something similar from the major paint store brand suppliers. You might go to the Ben Moore and Sherwin Williams sites to start for product specs and the name of the rep for such products near you. If, of course, the folks in your paint store cannot help. I suspect they will be able to do so or refer you to the same person if they cannot. I suspect they will cut you a deal on paint for 10Ksf as well but not unless you ask.
Abatron has great industrial products but they are pricey. Customer support is helpful and actually knows the products. I don't think they wear orange or blue aprons when talking on the phone either. They will not refer you to the plumbing department for a light switch though.
http://www.abatron.com/coatings.html
US Coatings has some nice environmentally friendly, low VOC industrial concrete coatings too. I was just starting to use a lot of their products when I was taken out of the race.
http://www.uscoatingsolutions.com/concrete-paint.php
Just stay away from box store brands or you will have 10Ksf of a mess.
Tags
concrete , floor paint , oil base primer
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
