Concrete Basement Floor Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 11:37 PM   #16
Registered User
Rewards Points: 5,514
I was surprised finding your location, from your other posts, so far "East Coast", wow; http://maps.google.com/ You live closer to Spain than to me...just across the water, lol.
I would not waste any paint unless trying to use it up as a temp. decoration. The slab temps in the spring/summer lag behind winter temps leaving your basement floor cool where outside warmer air could condense on the concrete- painted or not; pp.4; http://www.buildingscience.com/docum...g-your-basment
Average slab temps are about 10*F warmer than surface water temps because it is 6' below-grade; "Surface water temperatures on the Atlantic side reaches a summer average of 12 C (54 F) inshore and 9 C (48 F) offshore to winter lows of −1 C (30 F) inshore and 2 C (36 F) offshore." From; http://en.wikipedia.org/wiki/Geograp...d_and_Labrador
The Delta FL is good, as is foamboard/furring strips or f.b./plywood as the link said. http://www.cosella-dorken.com/bvf-ca...roducts/fl.php
No reason to paint (esp. Driloc $$) or seal the slab, as said; the products equalize any pressure drive from below, fig.3; http://www.buildingscience.com/docum...ms?full_view=1
Gary
Old 04-22-2013, 11:32 PM   #17
Registered User
Posts have been removed for breaking a forum rule- showing disrespect to other members. Please try to remember, Gary
Carry on with discussion, sorry for the interruption. Gary
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Concrete Basement Floor Prep BillyPilgrim Flooring 3 10-12-2012 09:35 AM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
