Concrete Basement Floor Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 06:42 PM   #1
Rewards Points: 169
Concrete basement floor paint
Can I paint a concrete basement floor with interior paint? I'll most likely be putting a subfloor over the concrete anyway, but I figured I should cover it up.
RCGA is offline   Reply With Quote
Old 04-19-2013, 06:52 PM   #2
Rewards Points: 13,250
Why would you paint it knowing it's the wrong paint and it going to be just a peeling mess.
What do you mean there's going to be a subfloor?
Whats the finished flooring going to be?
Old 04-19-2013, 07:19 PM   #3
Rewards Points: 169
I'll be laying hardwood.
Primary reason is to save money ish
Old 04-19-2013, 07:34 PM   #4
Yes, with the proper preparation most interior paints are spec'd for masonry. Now, as to what is the best wearing finish for a floor that's another question. Interior wall/trim finishes are not formulated to be walked on, so they won't wear well. If you're considering putting hardwood down, and if it's currently unfinished, you might consider a moisture blocking finish, like Drylock.
Old 04-19-2013, 09:33 PM   #5
Dri Lok is not made to walk on.
Real hardwood should never be layed over a slab.
You need to be looking into engineered flooring instead.
Old 04-19-2013, 11:09 PM   #6
Faron79's Avatar
Rewards Points: 260
Correct on the Drylok-
NOT made for horizontal uses.
I believe there are breathable flooring membranes for some types of Woods. Ask/research some flooring dealers/sites.
Faron
Faron79 is offline   Reply With Quote
Old 04-20-2013, 01:08 AM   #7
I'll take your word on engineered flooring over slabs, makes sense. However, I was suggesting Drylock as a barrier under the new floor, not as a surface finish to be walked on. From Drylock, "Not recommended for use on horizontal surfaces subject to foot traffic." It's not flagged for horizontal uses, only walking on it.
Old 04-20-2013, 07:18 AM   #8
Rewards Points: 169
Sorry, I should have clarified: I have a concrete basement floor. I'd like to paint/seal it up. Then I'll be laying a Delta FL subfloor, and then engineered hardwood.
I'm still not sure if I could use regular acrylic latex paint or should I spend the extra and get the 1 part epoxy concrete paint for garage floors? Like this: http://www.homedepot.com/p/BEHR-Prem...0201/100113293
Old 04-20-2013, 07:27 AM   #9
Rewards Points: 101
Hold on , I've got to get some popcorn.
JMDPainting is offline   Reply With Quote
Old 04-20-2013, 07:28 AM   #10
Rewards Points: 169
Oh dear, am I going in the wrong direction?
Old 04-20-2013, 07:35 AM   #11
Rewards Points: 101
Inside joke, whenever Behr paint is mentioned here all heck breaks loose.
Old 04-20-2013, 08:09 AM   #12
Rewards Points: 2,238
There's "Engineered" flooring -
It's put down with mastic - directly on the (clean)concrete.
Not cheap!
A lot of fun to install!
No "hardwood" directly on concrete!
"RF"
Oops!
You glue a pad down first!
rossfingal is offline   Reply With Quote
Old 04-20-2013, 12:11 PM   #13
Too Short? Cut it Again!
I don't see what you gain but added expense putting a sealer on it if your plan is to float a floor over it.
If you are painting because you are not going to get to the finish floor for awhile? Here is a novel idea. Use a floor paint. I like Ben Moore's reinforced products. They are self-priming (not paint and primer in one though) over nicely prepped concrete. Both oil and waterbased products come in lots of factory colors. Oil-based is urethane reinforced and the waterbased is epoxy reinforced.
With a little creativity you can do nice things with a painted floor and some painters tape. Concrete stains can be beautiful too.
Old 04-20-2013, 05:42 PM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
I will chime in and ask this
WHY paint the concrete if it is going to have a sub floor and another floor out over it.
Would not the person installing the sub floor put down the proper coating(if needed) or whatever?
chrisn is online now   Reply With Quote
Old 04-20-2013, 10:27 PM   #15
Faron79's Avatar
Rewards Points: 260
I don't have any popcorn...just had some vanilla-custard w/ strawberries @ Culvers though......!
Drylok does have a nice floor-paint though. If you can't get the Eng.-Hdwd/membrane(s) down right away, your floor will look real nice untill then!
http://drylok.halibutblue.com/wp-con...012/08/cfp.jpg
Faron
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Concrete Basement Floor Prep BillyPilgrim Flooring 3 10-12-2012 10:35 AM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
