Cold Weather Painting - Painting - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 11:57 AM   #1
Solutions (handyman)
Rewards Points: 364
Cold weather painting
Is painting with a latex exterior paint in cool weather okay? I understand the "ideal conditions" but sometimes this isn't possible. Will paint cure properly if it is applies when above freezing but freezes over-night? What are other suggestions?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 10-03-2010, 10:41 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
This is the tricky time of year. You will have heavy dew in the mornings and that also means heavy dew at night which means if your paint desn't have a few good drying hours before hitting the dew point, your paint could leech out. That's when the paint ingedients haven't completely evaporated when the paint hits the dew point and they are left to run down the surface of the paint. They can sometimes be washed right off.
If any paint hits the freezing point without completely drying can cause it to crack, bubble or peel but it's rare.
In short, give your paint a few good drying hours before dark and you should be fine.
Old 10-04-2010, 10:54 AM   #3
Rewards Points: 364
Thanks Mathew, makes sense.
Old 10-04-2010, 09:03 PM   #4
Rewards Points: 150
Thanks.
Some paint companies, like Pratt and Lambert, have 35 degree, low temp paint. That mean if it is cold and DRY, you can paint as low as 35 degrees F, BUT the temp has to be going UP from the time you start. And then it will dry at 35 degrees and onward.
hammerheart14 is offline   Reply With Quote
Old 10-04-2010, 09:48 PM   #5
worst part about cold weather painting is the dry time and coating. its much easier to get runs when it's cold due to the paint not flashing nearly as fast
racebum is offline   Reply With Quote
CFLs and Cold Weather Jazan Electrical 3 02-19-2010 11:09 AM
PVC pipe & cold weather Bernmeister Plumbing 4 01-11-2010 11:37 AM
Tiling in cold weather pglc Flooring 3 11-20-2009 05:13 PM
Cedar Decking and Cold Weather project_guy Building & Construction 3 01-29-2009 05:32 AM
Cold Weather Interior Painting psustang89 Painting 7 05-18-2008 11:47 PM
