Cold Weather Interior Painting - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2008, 07:41 AM   #1
I have a large living room to paint. It consists of 3 outside walls and I live in western PA. The house was built in the 1940's and does not have the greatest insulation. How will temps in the 30's (F) affect the paint on these outside wall, especially the corners? Am I better off waiting for warmer weather? Thanks.
psustang89 is offline   Reply With Quote
Old 01-29-2008, 08:13 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
It depends on the paint, but the easiest way to put it is that it will take longer to dry and cure
Figure on extra time for everything
Conceivably, if the substrate (surface you are painting) is too cold, the paint may not work well at all, but it would have to be pretty cold inside for this to happen
If you have one of those laser surface thermometers handy that would tell you for sure
slickshift is offline   Reply With Quote
Old 01-29-2008, 11:26 PM   #3
Thanks. What surface temp is too cold? My house is usually around 66F, but I'm assuming the outside corners will be colder.
Old 01-30-2008, 12:17 PM   #4
Painting contractor
There are paints out there that only requires a surface temp of 35 degrees. Check with your local paint stores such as Sherwin Williams. Check the store employees and the label on the can for temp required.
Thepaintman is offline   Reply With Quote
Old 01-30-2008, 04:43 PM   #5
slickshift's Avatar
Mostly you want it above 50*
Old 03-24-2008, 11:30 AM   #6
Paint Contractor
Why not get a gas heat blower to run? That would warm everything up and then paint? Enen at 50 degrees you should be fine though I have painted with colder surfaces without problems using Benjamin Moore.
movado is offline   Reply With Quote
Old 03-24-2008, 12:42 PM   #7
concretemasonry's Avatar
Rewards Points: 2,608
The key factor is the temperature of the WALL and not the air temperature.
Get a laser thermometer. - You can also use it to check out your freezer, refridgerator and temperature of your grease before you fry.
You should be concerned with the temperature of the wall and applied paint, which affects the drying and curing. You will also notice that with latex paint, the temperature of the applied paint will go down as moisture evaporates.
concretemasonry is online now   Reply With Quote
Old 05-18-2008, 11:47 PM   #8
Paint Contractor
I have had to do plenty of interior painting during the winter because heat was not available yet. If you aim a gas heater to blow into the room the walls will warm up. The room will be very warm and not a room to hang out in but the walls will be warm enough to conduct some interior painting.
Cold Weather Concrete in Post Hole OK?? Jerrycast Building & Construction 6 01-25-2008 09:47 AM
Cold water pressure low Showerpower Plumbing 2 01-20-2008 07:25 AM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 05:06 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
