Old 08-19-2012, 08:57 AM   #1
Which clear topcoat?
I'm looking for suggestions. I stained an exterior fiberglass door with Minwax gel stain. It gets very little exposure to rain and sun. I want to coat it with a high gloss clear. I just want to do 1 coat and if I have to recoat every year thats fine. I'm in south Florida so cold/freezing is not an issue. What do you think?
thanks,
Jim
jimamoses is offline   Reply With Quote
Old 08-19-2012, 11:40 AM   #2
Good luck with that idea, with just one coat better plan on have to sand and reseal every year. Just not going to be enough build up.
This is the best longest lasting finish I have ever used.
If it will hold up on a boat used in salt water in direct sun, it sure will hold up on a door.
It's not cheap but well worth it for eaze of use.
http://bristolfinish.com/
Old 08-19-2012, 11:56 AM   #3
I've never worked with fiberglass but i always use Varathane. Produces a very nice finish in one coat, i rarely do more than one coat but ALWAYS use sanding sealer and sand smooth before top coat.
tvanharp is offline   Reply With Quote
For my refinished deck: BM Arborcoat Semi Transparent + Protective Clear Coat Domochu Painting 0 05-30-2011 11:47 AM
Painting Kitchen Cabinets. Do I need a clear topcoat? tigereye Painting 1 11-23-2009 03:35 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 05:45 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
