Clear Poly??? - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2005, 03:11 PM   #1
clear poly???
Hi all,
I recently baught a new home and have been doing some major renovations. My wife was in charge of the kitchen cabinets and worked her butt off sanding, priming, sanding, and painting. She wanted a high gloss finish so she then applied a coat of poly. When she woke up in the morning all the white paint had yellowed and the light green she used darkened as well. She about broke into tears...
I was wondering if anyone knew if there is a polyurethane that dries clear? Or if there is an alternative product that would provide the same results as poly without the yellowing?
Thanks in advance
cmx0419 is offline   Reply With Quote
Old 08-15-2005, 10:29 PM   #2
Contractor
Sorry to hear about your plight. I'm old school and believe that only oilbased paints should be put over wood. IMHO latex covers, oils bind.
Teetorbilt is offline   Reply With Quote
Old 08-16-2005, 08:34 AM   #3
Paperhanger/painter
ProWallGuy's Avatar
Ben Moore sells an water-based poly called "Stays Clear".
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 08-16-2005, 10:49 PM   #4
Thanks guys. Since I'm too late to use the oil based paint, i'll give the benjamin moore poly a try.
Help needed 3/4 poly pipe joining sections. TomClarkInLubbock Landscaping & Lawn Care 3 08-13-2007 06:44 AM
problem with clear picture on tv ontap Home Theater 6 05-29-2007 08:13 AM
Bona Traffice over oil based poly christy123 Flooring 6 03-30-2007 06:57 AM
paint/ oil based poly ? thecrew74 Painting 6 05-19-2006 06:49 AM
Poly interior doors gregrice Painting 4 05-15-2006 12:35 PM
