Clear exterior wood finish for natural color
Most clear exterior deck sealers provide minimal to (realistically) no UV protection
It generally takes some tint to protect against UV rays
However, as this is on a ceiling, I'd suggest that an exterior deck sealer is not the proper product
Even though it's a porch, and perhaps somewhat exposed compared to a true interior, a quality urethane would be the most common coating for your application
As the ceiling wouldn't get direct UV rays, that type of protection isn't really the priority
Oil-based polyurethanes will last longer (than water-based), but will have a slight tendency to age with a more golden hue
Water-based urethanes generally won't last or protect as well, but tend to stay clear
Teak and tung oils will provide a beautiful finish, but would be labor intensive
They will also tend to "change color" a bit with age
I'm not familiar with cypress, if it's an oily wood then a teak-type oil may be the best, as urethanes don't work well with those type of woods
Other than that, it seems a urethane would fit the bill
