Cleaning Walls - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2010, 05:17 PM   #1
Rewards Points: 14
Cleaning walls
Just bought some Zinnser 123 primer to paint previously painted drywall.It says not to use TSP as a cleaner.Why is this? What do I use instead?
Thanks, Glenn
G Archer is offline   Reply With Quote
Old 12-29-2010, 05:35 PM   #2
Faron79's Avatar
Rewards Points: 260
If not rinsed REAL well (LITERALLY 2 or 3 times), TSP can leave a haze that can screw up even a good primer like 123.
At our store, I HIGHLY recommend POWDERED Dirtex.
(The trigger-bottle Dirtex states not to use on walls...different ingredients than the powder)
The BIG plus with this is that it requires no rinsing, unless walls are real dirty. Cleaning up nicotine after a smoker would require a few passes/rinses though!
I've used Dirtex myself too.
A little box for $2.99 will last a loooong time. You only need a 1/4-cup in a gallon of warm water for normal cleaning. Good hardware stores will have it...some groceries too.
Faron
Faron79 is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
cleaning exterior masonry walls TomMac Building & Construction 1 10-11-2010 02:40 PM
Cleaning candle wax off walls spaceman spif Painting 4 09-23-2010 09:21 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Cleaning Walls after wallpaper removal saggdevil Painting 28 06-16-2009 04:32 AM
