Old 06-30-2006, 03:39 PM   #1
cleaning walls
I'm prepping for paint this weekend. In the past I've washed walls with water prior to painting. No TSP or anything. I have to use something to clean the kitchen ceiling though. It's worse than I thought. The grease isn't visible but I can feel it on the paint. I was going to use TSP but someone suggested using Palmolive ultra oxy plus dish liquid because it's phosphate free and does just as good a job without having to worry about rinsing it real good. I was told TSP is not totally rinsed off the surface it can cause adhesion problems down the road. Anyone ever use dish liquid to wash walls before paint?? thanks
farrington135 is offline   Reply With Quote
Old 07-01-2006, 07:59 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
cleaning walls
Sounds horrible
You'd have to rinse that for sure....a lot
slickshift is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
