Cleaning Up Interior Window Sashes - Painting - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 01:56 PM   #1
cleaning up interior window sashes
I have some interior sashes i want to clean up before painting, there is some paint flaking. How would you go about cleaning this up.
I tried a scotch brite pad that didn't work to good. I was thinking about a small brass wire brush.
Thank you for any advice.
Joe Tilghman is offline   Reply With Quote
Old 06-07-2012, 05:17 PM   #2
DIY staff
Rewards Points: 7,174
Sand paper actually works well---remove the sashes and clean and paint them on a table---much easier to get a good job ---
Old 06-07-2012, 05:32 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Agree with sandpaper. Depending on the shape, 120 is a pretty good grit. Not to agressive, but enough to clean them. If the paint is chipping badly- scrape with a putty knife ( or 5 in 1- made for the job!) , and possibly step up the grit to 80. prime them with a good primer sealer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-08-2012, 06:38 AM   #4
thanks all for the advice
Old 06-08-2012, 08:18 PM   #5
Too Short? Cut it Again!
80 grit only if you must and I would smooth out the grooves you carve with 120 grit afterward.
You want a SHARP pull type scraper for this.
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 11:21 AM
Storm sashes for Andersen windows? Thunder Chicken Windows and Doors 12 01-05-2012 10:54 AM
Building Barn Sashes Clutchcargo Carpentry 9 12-17-2011 10:44 PM
can bad cleaning destroy your furnace eolsunder HVAC 1 09-22-2011 02:52 PM
