-   -   cleaning up interior window sashes (http://www.diychatroom.com/f4/cleaning-up-interior-window-sashes-146330/)
Joe Tilghman 06-07-2012 01:56 PM
I have some interior sashes i want to clean up before painting, there is some paint flaking. How would you go about cleaning this up.
I tried a scotch brite pad that didn't work to good. I was thinking about a small brass wire brush.
Thank you for any advice.
oh'mike 06-07-2012 05:17 PM
Sand paper actually works well---remove the sashes and clean and paint them on a table---much easier to get a good job ---
Brushjockey 06-07-2012 05:32 PM
Agree with sandpaper. Depending on the shape, 120 is a pretty good grit. Not to agressive, but enough to clean them. If the paint is chipping badly- scrape with a putty knife ( or 5 in 1- made for the job!) , and possibly step up the grit to 80. prime them with a good primer sealer.
Joe Tilghman 06-08-2012 06:38 AM
thanks all for the advice
user1007 06-08-2012 08:18 PM
80 grit only if you must and I would smooth out the grooves you carve with 120 grit afterward.
You want a SHARP pull type scraper for this.
https://encrypted-tbn3.google.com/im...UY-wBY3LdZJfLr
