Cleaning Steel For Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 05:53 PM   #1
Cleaning steel for painting?
I am in the process of building a steel patio cover in my back yard. I went to pick up all the steel the other day and It's covered with a black greasy film. I am going to paint this as soon as I weld the structure. Any ideas on how to clean this film off.
I have heard of using muratic acid (diluted) for this. Any ideas.
Moderator: Please move this to the painting forum...sorry
ebjack is offline   Reply With Quote
Old 03-08-2008, 10:58 PM   #2
Rewards Points: 5,336
I would use mineral spirits, it's a lot less aggressive then acid.
Ron
Old 03-09-2008, 08:05 AM   #3
This may seem a bit silly but,dawn dish detergent and a scrub brush seems to be a great grease cutter.I have used it before I used other more harsher chemical products.
mark942 is offline   Reply With Quote
Old 03-09-2008, 01:13 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,.....
The Above,+ a Good Sanding should get you ready for Primer,+ Topcoat....
Bondo is online now   Reply With Quote
Old 03-09-2008, 05:14 PM   #5
thanks for the replies. The I-beams are gonna be hard to sand but the rest should be easy.
Old 03-09-2008, 10:20 PM   #6
I've been wondering if sand or soda blasting would take the greasy film off of the steel. I would think it should do a good job of it, as long as, a person didn't use too much pressure. Or maybe even a pressure washer with about 1800 psi.
Handyman50 is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
cleaning stainless steel appliances? Yeti Appliances 3 12-11-2007 10:30 AM
Pros/Cons of Steel Siding moneymgmt Building & Construction 2 06-19-2007 03:57 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
steel under shingles orlockorlok Roofing/Siding 8 05-30-2007 09:44 PM
