Cleaning Paint Brushes-After Latex - Painting - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 02:42 PM   #1
Rewards Points: 170
I've been using some mid-grade brushes and I clean them with hot water, a wire brush, and then spin them dry. I am buying some high end brushes to paint my trim and was wondering if the wire brush may ruin the bristles?
I've seen that Purdy sells a brush comb and that is what they recommend. Think a wire brush is bad and I should get a comb?
How do you clean your brushes after using latex?
HandyFrank is offline   Reply With Quote
Old 01-11-2010, 03:52 PM   #2
Remodeling Contractor
no need for the wire brush. Before using the brush with latex, soak it in water to condition it. Then the paint will not wick into the heel, which makes it harder to clean. Search on youTube for some good videos on cleaning a brush.
Old 01-11-2010, 04:11 PM   #3
Rewards Points: 170
Good tip on soaking the brush, i'll try that.
I did a YouTube search and most people were washing them out, some using wire brushes, some using brush combs, and others just flexing it under the water until it ran clear.
Old 01-11-2010, 04:21 PM   #4
Easiest on the brushes.
Old 01-11-2010, 05:36 PM   #5
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
You can use a grout or stripping brush. Allway makes a nice small rigid nylon brush. Page 21 listed as a stripping-grout brush.
http://www.allwaytools.com/2008cat/allway2008.pdf
Don't ever use brush and roller cleaner in the can, it will reduce the firmness in the bristles. If you have dried paint, Murphy's oil soap works pretty good. Load up the brush, wrap it in foil and let it sit for a day. It loosens the paint and conditions the brush both.
Certain quick dry primers are also hard on a brush. I usually have an old Purdy laying around for priming.
Kevin
Kevin M. is offline   Reply With Quote
Old 01-11-2010, 11:30 PM   #6
firehawkmph's Avatar
Rewards Points: 1,864
Frank,
After getting the excess paint out by rinsing, I use liquid dishwashing soap and work it into the brush, then I clean it with a stainless steel choir girl pad. I push the brush into the bottom of the washtub like you would to cut in a corner, in order to fan the bristles out. I stroke the bristles only in the direction of starting at the heel and going towards the tip. Rinse out the soap and spin a few times. Then make sure you smooth the brush back into it's normal shape and put it back in the cover to dry. If you don't have a cover, double up a paper towel and fold it around the brush and put a piece of tape on it or a rubber band. I have been cleaning them this way for over 30 years and still have some brushes that are over 20 years old and in good shape.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-12-2010, 02:30 AM   #7
Too Short? Cut it Again!
I find that rinsing brushes out as they start to build up makes them easier to clean at the end. I do clean thoroughly after each use. I use either diswashing soap or shampoo. I've had some luck with the paint remover and brush conditioner you can buy at a fine arts store. I usually do as suggested in one post and start new brushes off as trim brushes, cycle them for use with flat latexes, and finally use them for primers before retiring them. I wouldn't use a wire brush. The plastic combs are fine.
With possible exceptions for some applications where the brush is likely to be destroyed, I only use quality brushes. The low end ones are worthless and even most of the mid-range ones are not constructed well and I find I cannot trust them so they slow me down. I love supporting my local paint stores but every now and them find bundles of nice Purdy's and Woosters on eBay that I cannot pass up bidding on.
Old 01-12-2010, 09:38 AM   #8
Rewards Points: 170
Great tips everyone!
I will be referring back to this post as I get painting projects done over the next few days/weeks/months.
Old 01-12-2010, 07:09 PM   #9
Kevin M.'s Avatar
Rewards Points: 150
Originally Posted by firehawkmph View Post
Frank,
Mike Hawkins
Hi Mike,
OK, I'm not ashamed to admit I have no idea what a stainless steel choir girl pad is. It sounds evil, or at least oppressive. Stainless steel and choir girl seem be to non connecting in any and all situations. As far as how the pad relates? never mind. LOL!!
Is this vernacular inclusive or relative to the Ohio area, or am I so back woodsy, mid west conservative that I am unaware or this particular terminology.
Before I go into Home Depot and ask for a Stainless steel choir girl pad, would you give me something tangible, so I won't be embarrassed
Thanks MIke,
Kevin
Old 01-13-2010, 02:48 AM   #10
Don't do it for your paint supplies!
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
