Old 09-11-2011, 10:27 PM   #1
cleaning oil based primer off my body
I primed my walls today with Zinsser Coverstain, which is an oil based primer. I got some on my body. I do not wish to put mineral spirits on my skin. Do you have any suggestions on how to remove it?
I have found some success using an abrasive face wash, but it is expensive and I do not want to use too much of it.
Thanks.
-K
kuj0317 is offline   Reply With Quote
Old 09-11-2011, 10:30 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Baby oil.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
m1951mm (09-12-2011)
Old 09-11-2011, 10:34 PM   #3
Gymschu's Avatar
I love D & L hand cleaner for removing any oil-based paints from my skin. After that, a good cleansing with soap and water.
Old 09-11-2011, 11:03 PM   #4
Busy DIYer
picflight's Avatar
What kind of body is it? Rubbing alcohol works for most bodies.
picflight is offline   Reply With Quote
Old 09-11-2011, 11:58 PM   #5
Learning by Doing
Leah Frances's Avatar
Tar based shampoos also work along with all of the above.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 09-12-2011, 06:42 AM   #6
Doer of Many Things
poppameth's Avatar
Automotive store. Permatex hand cleaner. Always keep some on hand. If it was me I'd just douse myself with paint thinner. You already have oil on your skin anyway.
poppameth is offline   Reply With Quote
Old 09-12-2011, 06:54 AM   #7
Skin absorbs whatever is on it- I used a thinner rag forever- but not really a great idea over the long run.
All waterless hand cleaners work, but they have spirits in them mellowed with lanolin.
Oiling up before starting with baby oil or a crappy hand lotion keeps the paint from sticking and makes clean up much easier.
Old 09-12-2011, 06:55 AM   #8
m1951mm's Avatar
Here is another thread covering the same question with some different answers:
Re: cleaning our hands and face after a job
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 09-13-2011, 03:03 AM   #9
the baby oil helped, but I already had it on my skin, so it just thinned it out a bit. I definately see how putting that on first would have made this much easier.
I used mostly apricot scrub - a face wash with abrasive in it, then some baby oil, then more apricot scrub. It did the trick.
I'll try and get some Permatex.
THank you all for your suggestions.
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 15 03-24-2011 11:20 AM
Zinsser primer not drying kevinkk Painting 9 12-17-2009 09:56 PM
Oil based Primer? Kotik Painting 2 12-06-2009 10:57 AM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 10 08-18-2009 02:46 PM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
