-   -   Cleaning knotty pine t/g boards (http://www.diychatroom.com/f4/cleaning-knotty-pine-t-g-boards-278/)
barks 12-30-2004 09:15 PM
I have had a bear rug hanging on a knotty pine wall for 4 years. After taking the rug down the wall is lighter where the rug was hanging. How does one make the wall look the same again? The wall was sealed with varnish.
tonyh 12-30-2004 11:22 PM
*Exterior Texture Coating*
Hi Again folks,
I have a good question for you'all. A long time ago "Sears" came out with a thing called exterior TEXTURE COATING that was suppose to last forever on your house. My house is from 1957 and it has that coating on it. It starting to peel from the bottom up. I plan on painting this house sometime soon, but I need to fix this peeling problem. Anyone out there know something about how to repair this texture coating?, or what can I use to replace the repair area after I peel the loose chips....Any help will be greatlly appreciated!
thanks
tonyh..
Humble Abode 03-21-2005 11:06 PM
I know it's a lot of work but would be a fun project. Why not take the whole wall down to bare wood and re-stain/varnish it?
Humble Abode 03-21-2005 11:13 PM
Originally Posted by tonyh
Hi Again folks,
thanks
tonyh..
You could scrape as much of it as humanly possible away, removing everything that will come off the wall then take a palm sander with some 60 grit paper to smooth the edges of the old paint. Then get a good all purpose primer and prime anywhere the texture coating is gone.
If you paint over this with conventional paint you will end up with some areas being textured and some not. Go to your local paint store and ask the clerk about exterior texture additive. You will have to fiddle with the proportions a little but if the area is minimil you should end up with a pretty good match. You may need a little trial and error. Experiment with a few different additives. There are a lot of different products from foam to sand.
