Cleaning A Cedar Deck? - Painting - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:23 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Cleaning a cedar deck?
My deck is a little over 2 years old, the winter, bird poop and random leaves/crap have made it a little less good-looking than it was when it was new.
I sweep it regularly and try to scrub/hose the worst stuff off when I see it but I'd like to give it a good cleaning.
I found an article that says first use a water/trisodium phosphate mix and then a water/bleach mix.
Is that the way to go, or should I try something else?
CoconutPete is offline   Reply With Quote
Old 06-13-2012, 08:41 PM   #2
Oxalic acid is a wood cleaner. Used to clean and rehab old wood.
Tham
Tham is offline   Reply With Quote
Old 06-13-2012, 10:31 PM   #3
Rewards Points: 150
Sodium percarb or oxalic is best method to restore then seal with a semi trans oil based sealer.
CaptRandy is offline   Reply With Quote
New Cedar Deck Mold/Mildew Stains? Bannerr General DIY Discussions 12 08-18-2014 10:21 PM
Staining Cedar Deck covitamarie Building & Construction 3 09-18-2011 10:03 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Stripping and cleaning a partially repaired deck tigereye Painting 2 03-22-2009 10:51 AM
Can I seal a deck without cleaning it? goscottgo General DIY Discussions 10 02-03-2008 11:21 PM
