Cleaning Brush - Painting - DIY Chatroom Home Improvement Forum
Closed Thread
Old 02-03-2011, 12:28 AM   #1
Cleaning brush
I was told that I can use denatured alcohol to clean dried paint where the ferrule and nylon meet? Is this correct?
StevenH is offline
Old 02-03-2011, 04:21 AM   #2
Steven, alcohol and a wire brush will clean dried latex from the ferrule. But, paint on the outside is indicative of paint throughout the resevoir area of the brush. If you squeeze that area of the brush, does it feel hardened? If so, that will prevent the brush from functioning properly--it won't hold paint and will cause it to drip more. Getting the dried paint out of there will be a nightmare and next to impossible, since it's not going to melt and slide out. At 10 bucks a quart, you'll have to buy enough to fully sink the brush, then try to work the softened paint out with a brush comb, another few bucks. And, you still won't get it all out. You'll loosen it enough that it will work itself out as you're using it and you'll be picking it out of your finish as you paint. How much did the brush cost? How much is your time worth? Do the math. Get whatever you can out of the brush, for priming or a duster. Sorry my friend, it's that simple. When washing brushes, wire brush the ferrule area, trying to avoid tearing the ends of the bristles, and rinse for another minute after the water runs clear. The newer paints are harder to clean out of the resevoir.
DiyPaintingGuide.org
jsheridan is offline
Old 02-03-2011, 10:42 AM   #3
Super Master Painter
Ole34's Avatar
i spray my brushs with WD-40 after im done washing them.......for a brand new brush i soak in it a can filled with WD-40 then spin it out, makes cleans up easier and seems to help preserve the bristles..........maybe what i am doing is wrong but in my mind it seems right lol
Ole34 is offline
Old 02-04-2011, 01:04 AM   #4
Professional Painter
What I would do is to clean it is with paint thinner, let it soak it for a while and then see if it bends out. Or if the paint comes out of it. but soaking it for a while is an important key! I have a some if you want to look at them.
mattroefer is offline
Old 02-04-2011, 01:21 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
[quote=Ole34;583845]i spray my brushs with WD-40 after im done washing them.......for a brand new brush i soak in it a can filled with WD-40 then spin it out, makes cleans up easier and seems to help preserve the bristles..........maybe what i am doing is wrong but in my mind it seems right
For a "super master painter" this is -----
chrisn is online now
Old 02-04-2011, 06:06 PM   #6
Ole34's Avatar
[quote=chrisn;584384]
For a "super master painter" this is .
have you ever tried it ???? if not then keep your comments to yourself......wd-40 works for most anything, and it absorbs any moisture left in the brush and helps preserve the bristles..............oil is a natural preservative, maybe you didn't know that........i also spray some in my 5's and cut cans.....when it dries it leaves a protective film and the paint washes out easier..... i have been using the same buckets for years and they all look new still to this day. im not a Super Master Painter for nothin
Ole34 is offline
Old 02-04-2011, 06:11 PM   #7
Ole34's Avatar
is this ..............lol you are to easy, dont EVER underestimate the power of WD-40
Drives Out Moisture
58 uses found.
  • Drives moisture from door sill plate
  • Prevents moisture damage on cable TV field strength meters
  • Drives moisture from tire air nozzles after washing
  • Drives out moisture from trunk locks
  • Removes roof mastics from tools
  • Displaces moisture from spark plug wires
  • Displaces moisture from car wiring
  • Drives moisture out of trunk locks
  • Drives moisture from DC auto batteries
  • Drives moisture from electrical wiring in cars
  • Drives moisture from front struts
  • Drives moisture from convertible top hinges
  • Drives moisture from flooded engine
  • Drives out moisture from flashlights
  • Displaces moisture from submerged cellular phones
  • Drives moisture from outdoor latches
  • Drives moisture from moving parts of electric jewelry boxes after washing
  • Drives moisture from home wiring
  • Drives moisture from electrical contacts on weed eater
  • Drives moisture from wheel bearings in shower door wheels
  • Drives moisture away from pushbuttons that can become oxidized
  • Helps clean bilge areas
  • Spray on electrical panel boxes to drive out moisture
  • Drives moisture out of shovel handles
  • Drives moisture from seismic cable connectors
  • Drives moisture out of electric generators
  • Drive moisture from bottom of leaky coffee pot
  • Drives moisture from helicopter quadrants
  • Drives moisture from radar gear
  • Drives moisture from precision tools
  • Drives moisture from heavy-duty drills
  • Drives moisture from ignition coils
  • Drives moisture from ignition distributors
  • Drives moisture from spark plugs on tanks
  • Displaces moisture from electrical conduits
  • Drives moisture from telephone wire connections in network interface box
  • Removes hydraulic fluid from Lear jets
  • Drives moisture from pocket watches
  • Drives moisture from hearing aids and cleans battery compartment
  • Drives moisture from antenna connectors
  • Drives moisture from bird bath heaters
  • Displaces moisture from guns after cleaning
  • Drives moisture and mud from duck guns
  • Spray on bottom of wet running shoes to drive out moisture
  • Drives moisture from buckles on scuba diving belt
  • Drives moisture from fishing waders after use
  • Removes moisture between handle & shaft of golf irons
  • Drives moisture from wet bicycle chains
  • Drives moisture from fishing tackle
  • Drives moisture from lifejacket turnbuckles
  • Drives moisture from gyro compasses
  • Drives moisture from bicycle gear shifting cables
  • Drives moisture from bicycle bearings
  • Drives moisture from moving parts of compound bows
  • Drives moisture from boat trailer lights
  • Drives out moisture from jet ski spark plugs
  • Drives moisture from a boat's moving screws
Ole34 is offline
Old 02-04-2011, 06:12 PM   #8
Ole34's Avatar
On The Job
444 uses found.
Browse these Uses: 1 - 2 - 3 - 4 - 5</B>
  • Cleans resin encrusted table saw blades
  • Removes oil from hands
  • Removes tar from hands
  • Cleans jointer and planer blades before and after sharpening
  • Protects bandsaw bearings
  • Cleans spray paint nozzles
  • Cleans rusty saws
  • Removes pine pitch from table saw blades
  • Prevents rust on clamps
  • Keeps metal filing tools from filling with lead or zinc
  • Removes Cosmeline coatings from milling machines and other shop tools
  • Cleans gunk from safety glasses/goggles
  • Softens and dissolves dried manure from work boots
  • Spray on hole diggers to make dirt slide off easier
  • Spray on workbench to keep glue from sticking
  • Lubricates and protects bucksaw blades
  • Cleans debris from vise-grip
  • Cleans heavy lube from bull gears on Drag line
  • Cleans bed of metal lathe
  • Cleans reflectors on fluorescent lights
  • Keeps paint from sticking to paint brushes
  • Prevents breakage of contact pins and support when changing fluorescent light bulbs
  • Prevents rust on hand saws
  • Lubricates miter saw blade
  • Protects drives on wire welders
  • Cleans sawdust from wood working tools
  • Coat drill press spindle for rust protection
  • Cleans and protects jaws on electric drill chuck
  • Keeps table saw arbor from gumming up and sticking
  • Loosens gummy residue from carbide tipped blades
  • Cleans airbrushes after use
  • Removes rust from files
  • Cleans and prevents rust on oil tank exterior
  • Removes petroleum stains from clothing
  • Cleans and protects medicine door latches
  • Removes coffee stains from leather
  • Removes ink stains from leather
  • Cleans bed frame
  • Cleans newspaper ink from tables
  • Cleans gunk from chain saws
  • Removes stickers from credit cards
  • Removes stains from coffee cups
  • Removes oil stains from nylon
  • Removes labels from medicine bottles
  • Cleans chair wheels
  • Cleans roofing tar off circular saw blades
  • Removes marks-a-lot ink from most items
  • Cleans scum from rubber gloves
  • Helps remove shoe polish stains from socks
  • Keeps ax blade from rusting
  • Apply on medicine cabinet closure to prevent sticking
  • Cleans clogged Inkjet nozzle
  • Removes rust from rollers on storage shed door
  • Coat door knobs prior to painting to keep paint from sticking
  • Removes plastic cement from tools
  • Spray bottoms of storage containers to prevent sticking to shelves
  • Renews dried-up ink on adding machine ink rollers
  • Removes cement from metal
  • Cleans Plexiglass
  • Cleans magazines for an AK-47
  • Cleans window caulking
  • Cleans and protects forklifts from rust
  • Cleans overhead projectors
  • Coat dental instruments before putting in autoclave to prevent excessive oxidation
  • Cleans gunk from pricing guns
  • Spray on metal stencils before painting to ease removal of dried paint
  • Protects steel doctor blades on flexographic printing presses
  • Protects metal water meters from rust and corrosion
  • Prevents corrosion on helicopter blades
  • Cleans dirty power cords
  • Cleans and lubricates commercial coin rollers/counters
  • PMCS (Preventative Maintenance Checks and Service) of military issued weapons like the M16A2 rifle
  • Cleans rust on conveyors
  • Cleans stickers off postal mail sorting equipment belt rollers
  • Cleans engraving machines
  • Cleans bed pans
  • Helps protect sluice boxes
  • Helps remove rust from calipers
  • Cleans and protects sewer cleaning cables
  • Removes paint from windows
  • Removes tape marks from dry erase boards
  • Remove tape from office furniture
  • Cleans gunk from phone buttons
  • Cleans and protects manicuring implements at beauty shop
  • Cleans adhesive tape residues on audio/visual cables
  • Removes crater grease from rail lines
  • Removes transparent tape from x-ray machines
  • Removes fingerprints from glossy covers of magazines and book covers
  • Removes permanent marker from dry erase boards
  • Keeps construction lifts clean from stucco job
  • Cleans blades on box cutters
  • Cleans pushbutton switches on hand controls for patients‚€™ hospital beds
  • Removes dried caulking from hands
  • Protects coaxial fittings on modem
  • Helps remove hands from stuck pipe
  • Removes asphalt from overshoes
  • Cleans salt-impregnated ice from the soles of my work boots
  • Coolant and polishing agent in a grinding operation
  • Cleans axe blades
  • Cleans tape and glue left from microscope stand and equipment
  • Cleans and protects wire mesh black bay boxes
  • Cleans and protects jet compressor blades
  • Protects motors coupled to pumps to prevent faulty packing glands
  • Cleans and protects Automatic weapons
  • Cleans and protects cargo release systems
  • Cleans and protects heavy-duty cutting heads
  • Cleans and protects reamers
  • Protects against corrosion on high tension circuits
  • Prevents corrosion on wing interior
  • Protects helicopter M/R blades from rust
  • Cleans and protects forklift brake hardware
  • Cleans welding dust
  • Provides protective coating for Teflon heating strips
  • Cleans shoe repair equipment
  • Cleans and protects moving parts of old printing presses
  • Helps clean oxidization from bronze grave markers
  • Spray in a box of nails to keep them fresh and rust-free
  • Removes rust from old keys
  • Keeps circumference rulers from rusting
  • Protects drywall tools
  • Spray chalk lines drawn on asphalt to keep them from washing away in the rain
  • Helps maintain waterproof seal in telephone splice cases
  • Spray on main valve for pond pumps to check for a tight seal
  • Use as a tapping lubricant
  • Cleans printer toner from unwanted places
  • Cleans gum from parking meter coin slot
  • Frees up extendable paint roller poles that get clogged with paint
  • Lubricates paper cutter blades
  • Lubricates and protects electric stapler
  • Eases removal of solidified spitballs
  • Removes duct tape residue from work boots
  • Keeps knobs on heart monitor defibrillators clean
  • Removes gunk from cooler doors
  • Removes deposit buildup on sand belts
  • Lubricates antenna parts on tall broadcast towers
  • Helps remove a chair base from a press fit hydraulic cylinder
  • Cleans and protects areas affected by bi-metal conditions and disassembly of machinery
  • Prevents rust on testing bars
  • Prevents rust on floor sanding machines
  • Lubricates and cleans tension idlers on theater rigging system
  • Protects plumbing "runner" ropes from being burned by molten lead
  • Spray on bed liners to keep rebar from sticking
  • Cleans and protects outdoor popcorn stands
  • Lubricates hacksaw blades for cutting metal
  • Lubricates precision grinding saws
  • Eases removal of concrete grout from test cubes used in construction
  • Keeps tape from sticking to drywall tools
  • Removes rust from stainless steel vault doors
  • Cleans plastic desk protectors
  • Hides scratches on metal elevator doors
  • Spray on sewer vent cover to keep it from freezing shut
  • Keeps lock down plate clean on oil wells
  • Removes surgical tape from hospital bed rails
  • Removes glue from copper foil during stained glass production
  • Helps hide scratches on plastic safety goggles
  • Cleans concrete from shovels
  • Reconditions rollers in fax machines
  • Removes ink from rollers in printing press
  • Removes evidence tape glue from evidence tape after evidence has been processed
  • Cleans and shines the exterior of stainless steel frozen yogurt machines
  • Hides small scratches on woodwork
  • Spray on paint before scraping to make paint come off easier
  • Increases life of high-speed dental hand pieces
  • Helps provide dust-free surface when roofing
  • Removes chewing gum from lunch trays
  • Removes roofing tar from shoes
  • Use for science project on rust prevention
  • Cleans and protects handcuffs
  • Removes rust from dog tags
  • Protects archeological tools
  • Protects combination locks
  • Protects and maintains armor suits
  • Protects and polishes bronze grave markers
  • Lubricates and protects antique weapons for historical reenactments
  • Cleans clipper blades in dog grooming shop
  • Clean and polish Alaskan Oil Pipeline at visitor viewing
  • Removes tar and asphalt from soles of shoes
  • Cleans gum from boots
  • Spray on rag and wipe exterior to help clean CPR mannequins
  • Cleans airbrushes
  • Removes grease from lunch boxes
  • Removes spray paint from reflectorized street markers
  • Cleans magnifying glass handle
  • Cleans interiors of soda machines
  • Removes scuff marks from walkie-talkies
  • Shines atlas missiles
  • Cleans and protects safe deposit boxes
  • Removes gunk from bookbags
  • Removes tar from feet
  • Spray a little on the tips of "dead" ball point pens to clean them
  • Removes gunk from lace hoops on work boots
Ole34 is offline
Old 02-04-2011, 06:13 PM   #9
Ole34's Avatar
thousands of uses for WD-40 ...........key ingrediant in WD-40 is Fish oil
check out the full list here
http://www.wd40.com/uses-tips/category/on-the-job/
Ole34 is offline
Old 02-04-2011, 06:18 PM   #10
Ole34's Avatar
Browse these Uses: 1 - 2 - 3 - 4</B>
335 uses found.
  • Keeps paint from sticking to glass
  • Removes paint from dungarees
  • Removes paint from leather
  • Removes paint from lures
  • Removes paint from shoes
  • Lubricates airless paint guns
  • Removes paint from fishing lures
  • Removes paint from tile flooring
  • Removes paint rub from another vehicle
  • Penetrates to help open stuck paint can lids
  • Removes paint rub caused by 9 vehicles
  • Removes adhesive tape without damaging factory paint
  • Spray on a paint brush for an easy way to clean RC cars
  • Helps keeps paint on farm machinery shiny and free from cracks
  • Removes paint from tile flooring (be sure to wipe floor clean after using WD-40)
  • Use in art projects�the way the chemicals and oils react with paint is unique
  • Removes wax from flat black car paint to remove "cloudy" appearance
  • Spray tie down ropes prior to securing load to keep them from scratching truck paint
  • Cleans airbrushes
  • Cleans ashtrays
  • Cleans boats
  • Cleans dice
  • Cleans old coins
  • Cleans Plexiglass
  • Cleans volleyballs
  • Cleans and lubricates BB guns
  • Cleans and protects bayonets
  • Cleans and protects gauges
  • Cleans and protects pitchforks
  • Cleans and protects TV antenna
  • Cleans antique guns
  • Cleans axe blades
  • Cleans battery chargers
  • Cleans bed frame
  • Cleans bed pans
  • Cleans bike chains
  • Cleans bobby pins
  • Cleans bowling balls
  • Cleans candle soot
  • Cleans cell phones
  • Cleans cup holders
  • Cleans exterior of drums
  • Cleans fiberglass bathtubs
  • Cleans fox traps
  • Cleans furnace nozzle
  • Cleans golf balls
  • Cleans grime from engines
  • Cleans gum from horseshoes
  • Cleans gunk from pistons
  • Cleans Hemming dies
  • Cleans hoof trimmers
  • Cleans ignition wires
  • Cleans knife blades
  • Cleans lawnmower blades
  • Cleans marble windowsills
  • Cleans metal figurines
  • Cleans model T Jacks
  • Cleans motorcycle chains
  • Cleans mud from shoes
  • Cleans music racks
  • Cleans old muffin tins
  • Cleans piano keys
  • Cleans PVC valves
  • Cleans raccoon traps
  • Cleans reloading dies
  • Cleans remote controls
  • Cleans resin from waterpipes
  • Cleans rust off sprockets
  • Cleans rusty bolts
  • Cleans rusty doorknobs
  • Cleans rusty jewelry
  • Cleans rusty saws
  • Cleans smoke stains
  • Cleans spots off shoes
  • Cleans synthesizer keys
  • Cleans valves on compressors
  • Cleans window sills
  • Cleans woks�after cleaning
  • Cleans and lubricates hacksaw blades.
  • Cleans and lubricates rotary cutters
Ole34 is offline
Old 02-04-2011, 06:24 PM   #11
Registered User
Rewards Points: 5,266
Thanks for that! I learned a lot...... Only use it to clean decals and gum.
Gary
Gary in WA is offline
Old 02-04-2011, 06:57 PM   #12
Ole34's Avatar
i laugh when i see painters covering windows with PLASTIC or NEWSPAPER when painting exteriors ...wasting hours in the process and adding additional labor hours to the job all the while increasing the total cost for the job ................i spray the windows down with WD-40, roll the wall then wipe down the windows with a rag............done, and if i want i can charge extra for window cleaning
Ole34 is offline
Old 02-04-2011, 06:58 PM   #13
Rewards Points: 530
and how doesa it affect the ability of the brush to hol latex paint?
Would you use wd-40 to clean something then paint it with latex?
Wd leaves a film if my memory serves me right.
I hear it is not good for cleaning a gun.
boman47k is offline
Old 02-04-2011, 07:01 PM   #14
Ole34's Avatar
it doesnt affect my brushes at all...... most of it evaporates or something, i dont know lol ..........i havent had a problem in all the years ive done it
for guns i only use Break free
Ole34 is offline
Old 02-04-2011, 10:13 PM   #15
Experienced
Jackofall1's Avatar
Is the OP referring to cleaning a ferrule for a compression fitting with a brush?
I might be wrong, but thats what it sounds liket to me.
Mark
Jackofall1 is offline
Closed Thread
Cleaning paint brush of Kilz Original torsade Painting 2 10-31-2010 05:36 PM
cleaning pipes: emery cloth vs steel brush acerunner Plumbing 1 08-16-2010 07:05 AM
Cleaning Paint Stripper from Gummed Up Brass Brushes? Lovegasoline Painting 0 04-10-2010 02:13 PM
Mixing Mortar for Tuckpointing amakarevic Building & Construction 38 01-28-2009 08:00 PM
Cutting - in Illinois G.C. Painting 11 11-24-2008 03:04 PM
