#1 |
Clean walls before or after texturing?
We just moved into a new house that is in pretty rough condition... the previous owner was a heavy smoker, and the walls are quite dirty in a lot of areas; especially around the vents.
We are repainting and retexturing the whole house. My question is, should the walls be cleaned with TSP before or after we have the drywall guys come in for retexturing? If done after, should it be done before priming in order to seal it in? Thanks! |
#2 |
the Musigician
if the retexturing is being applied to the walls, i'd clean them first, yes.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Drywall and Painting Pro
Clean before you do any mud work or texturing.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Checkout some of To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Thanks guys!
#5 |
Good Luck!
| Display Modes | |
| How do I clean walls for painting? | jeffhweb | Painting | 5 | 06-05-2009 02:58 PM |
| Texturing walls...Question | Boeve | General Discussion | 2 | 06-02-2009 06:58 PM |
| How to clean smoke from fire, off walls | jerbark | General Discussion | 6 | 04-27-2009 04:29 PM |
| Texturing walls | S&R Painting | Painting | 2 | 02-02-2009 07:24 PM |
| Texturing over painted walls | l1r | Painting | 3 | 08-05-2008 11:52 AM |
