Old 05-15-2012, 07:36 PM   #1
Clay bar to remove paint from granite countertops
Had house painted and have a lot of small drops of paint on countertops. Would using a clay bar like used in auto detailing work? Trying to stay away from chemicals and blades. Thanks in advance.
Ajeagle6921 is offline   Reply With Quote
Old 05-15-2012, 09:01 PM   #2
Learning Things Every Day
Jay 78's Avatar
It sure would.
Under Construction
Jay 78 is offline   Reply With Quote
Old 05-15-2012, 09:21 PM   #3
I'd try a pastic putty knife.
Old 05-15-2012, 10:04 PM   #4
i doubt it would work.
why do you now want to use a razor blade ? that would take all of it off in a very short time, with no damage.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 05-15-2012, 10:47 PM   #5
Jay 78's Avatar
And you're basing this statement on...what, exactly?
To the OP: What material is your counter top? I'm asking just out of curiosity because you said you don't want to use chemicals, not because the clay bar won't work. It WILL work. Just keep it moist with water.
Under Construction
Old 05-15-2012, 11:06 PM   #6
i have used it many times. and i have had to get paint off of granite.
Old 05-16-2012, 03:55 AM   #7
paper hanger and painter
chrisn's Avatar
Get the lousy painter back that did the lousy job back to fix it.
A fingernail will work in most cases, latex, hot water and a rag.
chrisn is online now   Reply With Quote
Old 05-16-2012, 07:35 AM   #8
dogris's Avatar
Ha! my thoughts when I read OP's OP.
dogris is offline   Reply With Quote
Old 05-16-2012, 08:44 AM   #9
I thought about having painter remove it, but I'm afraid he will be rough with the granite and scratch it. I'm sure I'm being overly cautious but know how expensive of a fix it could be. So some of you have used a clay bar and it worked well?
Old 05-16-2012, 06:07 PM   #10
chrisn's Avatar
Sounds like a fly by night painter to me, probably no insurance and or license to do the job properly. I cannot imagine any pro would not know how to remove it without scratching it, but then again, I don't know of any pro that would get paint where it does not belong to begin with.
They make these things that pros use called drop cloths
The Following User Says Thank You to chrisn For This Useful Post:
Jay 78 (05-16-2012)
Finding a good granite fabricator for kitchen countertop tseverson Kitchen & Bath Remodeling 5 04-20-2012 03:50 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
How to remove paint from brick beezee3 Remodeling 2 12-28-2005 02:38 AM
