Choosing A Paint Primer... - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 08:27 PM   #1
Trucon01's Avatar
Rewards Points: 510
Choosing a paint primer...
Hi All,
I'll be finishing my basement in all drywall. I've read that the BM Fresh Start and SW PrepRite are the better primers. Any reason why I should choose one over the other?
Trucon01 is offline   Reply With Quote
Old 02-05-2012, 09:51 PM   #2
ltd
Rewards Points: 536
ill be using s/w prep rite pro block tomorrow. i like it. b/m fresh start, cant really say from experience but i would say its a top primer and you would have no problems . flip a coin you cant go wrong
ltd is offline   Reply With Quote
Old 02-05-2012, 09:56 PM   #3
Rewards Points: 582
yes both are good you can't loose..ben
Old 02-06-2012, 07:46 AM   #4
Too Short? Cut it Again!
I used both for years. People I trust posting on the site seem to like Zinser priming products and they might save you a bit. Just stay away from box store stuff.
Old 02-06-2012, 04:55 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
All depends what the finish sheen of your paint is. If it is an eggshell or more, you want a prime that will seal the rock good enough to have " enamel holdout"- which means the surface won't continue to suck the sheen out of your finish coats after the prime.
Either of your choices are very good- as sds said some like me like Zinsser products ( Which BTW sds- are found at the box stores..)I would have no problem using Zin's 123 for that.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Behr Paint and Primer in one. Matthewt1970 Painting 9 09-30-2010 04:48 PM
Latex paint over oil primer - did I mess up? wrighter Painting 2 10-21-2008 01:25 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
Painting melamine particle board Otchen preeatnah Painting 4 06-24-2008 10:02 PM
