Chips On Corners Of The Wall - Painting - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 06:43 PM   #1
dSilanskas's Avatar
Chips on corners of the wall
Question what would you guys use to fill in small chips on the corners of the walls. Like how you get little chips and you can see the metal that they put on the corners when joining two pieces of sheetrock?
dSilanskas is offline   Reply With Quote
Old 03-15-2009, 08:28 PM   #2
Rewards Points: 506
Assuming the chip isn't long, spackle should do fine.
SirWired
sirwired is offline   Reply With Quote
Old 03-16-2009, 08:25 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Those corners are tough
If it was a big enough chip where I wouldn't want to just feather-sand it out and forgo the "filler" and just touch-up paint, I'd spot prime (<--this is important if metal is showing to keep it from just falling out again), and use a lightweight latex spackle
slickshift is offline   Reply With Quote
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Rounded wall corners Jiffner Painting 6 06-08-2007 08:58 PM
