Chipping Latex Paint On Masonite Prep Question - Painting - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 05:29 PM   #1
Chipping latex paint on masonite prep question
I am trying to prep my garage door for a new coat of paint. On the bottom edge of each board there is flaking and chipping of the paint. When I sand this more and more paint rips off, I could keep sanding until
no more paint is left on the entire board. What is the best way to prepare these chipping area's for paint? I've sanded the area down and have only moved the chipping area's because I still have loose edges around the area I sanded. Any Input greatly appreciated, Thank you!
Brettjones is offline   Reply With Quote
Old 10-17-2011, 05:26 PM   #2
Too Short? Cut it Again!
You want to get all peeling, flaking and otherwise loose paint off so if you have to sand the whole thing you should. It will just come back to haunt you later. Then apply a quality paint store primer and two coats of finish. I like Benjamin Moore Alkyd Fresh Start but a bonding latex will work too. Tint it 40 percent of your color mix to help coverage along.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
Painting a garage door dfoxworthy Painting 6 06-22-2008 10:51 PM
