Chipping, Cracking Layers Of Paint-possible Calcimine - Painting - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 07:59 PM   #1
chipping, cracking layers of paint-possible calcimine
My 1930's built house has 3 rooms with (ugly) textured walls and coves. Over the past years the top layers of latex paint have been chipping and cracking off steadily, revealing an oil paint beneath. As I was preparing the walls in the living room for paint (scrape, sand, wash with TSP) the paint loss was neverending. Uncovered during the prep was a surface that may possibly be calcimine - it is green colored and very chalky. After researching this I decided to bite the bullet and just get all of the old paint layers off and start fresh since the amount of patching for all of the uneven paint layers would have taken me forever anyways. What i found were more areas of the green but also areas of what I think is the plaster(white). The old paint pretty much just falls off the walls if I get a loose edge started. It is very crispy. My question is this: if I get the calcimine washed off what would be the best next step? I want the texture GONE and it seems to be easily smoothed with light sanding - is this a viable option? Or would a skim coat be a better idea?
doornumber3 is offline   Reply With Quote
Old 04-18-2010, 04:38 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
After the calcimine is completly gone , prime with an oil based primer, and paint.
Old 04-18-2010, 10:31 AM   #3
Thanks for the reply. Which is preferable - BM calcimine recoater or can you recommend something else? Will I be ok sanding the texture off of the old plaster to smooth it out?
One more question: is milk paint the same as calcimine? My dad always used to tell me that was probably what was causing the paint failure. I know nothing about any of this except what I've learned from searching this forum - lots of information here!
Old 04-18-2010, 02:52 PM   #4
I've attached a couple of photos to show what I'm working with. Thanks again for any help.
chipping, cracking layers of paint-possible calcimine-livingroom001.jpg   chipping, cracking layers of paint-possible calcimine-livingroom002.jpg
Old 04-18-2010, 06:31 PM   #5
chrisn's Avatar
Rewards Points: 136
BM recoater is perfect
sanding, yes or prime and skim it out
milk paint, that I don't know,I think not but am not sure
Old 04-18-2010, 07:08 PM   #6
Rewards Points: 526
Milk paint is different from calcimine. Calcimine was used with plaster walls because it was unaffected by the ph levels of the plaster while it was curing. Because it was essentially a chalk based paint, eventual failure is almost guaranteed. Milk paint on the other hand was/is made from (I believe) curdled mild and is extremely durable. I have read that it was not often used as a coating for homes, but rather as a furniture paint.
Windows is offline   Reply With Quote
Old 04-19-2010, 10:35 AM   #7
Thanks again for all of your help.
So after seeing the photos do you think the green color is the calcimine? It's very weird how it comes off on the back of some of the old paint and sticks in other places. It definately is very chalky and even the white plaster has a chalky feel (though not nearly as much as the green). My dining room has a goldish brown color that is acting like the green color. Sigh
Old 05-11-2010, 12:16 PM   #8
maybe its not calcimine
Update:
I successfully removed all of the old paint from the walls and coves. Now for the next issue:
The texture part of the plaster is very powdery - it literally falls off the walls with a mild scrape of a razor/scraper. Underneath is the hard plaster. Sooooo I am removing the powdery texture by scraping, and I will most likely need to skim a smooth coat to finish.
What product do I use to skim? What do I use to prime, and do I do prime prior to the skim coat?
Thanks in advance!!!
Old 05-11-2010, 12:26 PM   #9
Rewards Points: 526
Update:
I was involved in a similar situation in my house and I skimmed the walls with Durabond 90 (brown bag) which dries to a very hard, plaster like finish. I skimmed on top of that with ordinary joint compound, then primed 2 coats with latex primer. My walls look really good.
Old 05-16-2010, 11:34 AM   #10
That sounds like what I will need to do. Did you prime the bare plaster prior to applying the Durabond?
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
New Paint Job...Blistering, Cracking, Peeling... awluter Painting 21 10-17-2009 02:06 PM
Scraping chipping paint from a brick wall. Suggestions? smikhailov Painting 5 07-21-2009 12:48 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 11:38 PM
