Chemical Injector "in Reverse" - Painting - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 05:41 PM   #1
chemical injector "in reverse"
I've got a dewalt dp3750 pressure washer. It came with a chemical injector that threads into the pump right under the unloader. Instead of drawing chemical in, the container holding the chemical fills with water. If anyone could let me know what is causing this I would sure appreciate it.
thanks,
jim
jimamoses is offline   Reply With Quote
Old 03-31-2014, 05:47 PM   #2
Rewards Points: 12,840
Contacted Dewalt and asked them before coming here?
Old 03-31-2014, 06:18 PM   #3
Rewards Points: 5,974
Yes just had the same problem. There is a ball or check valve in the injector that is stuck. Cost me $5 (not a misprint) to have mine fixed.
Old 04-01-2014, 06:06 AM   #4
Dewalt was no help. Thanks for tip on valve!
jim
Chemical Used For Stripping Bathtubs Kills 13 BigJim Off Topic 6 03-06-2012 02:25 PM
Chemical analysis? Kasi General DIY Discussions 4 07-11-2011 09:59 PM
chemical free iron filter Buff35 Plumbing 1 08-02-2010 01:50 PM
Chemical paint remover on exterior cedar siding creamaster Painting 3 05-28-2008 06:58 AM
chemical ayuhmike Plumbing 3 03-24-2008 08:05 PM
