Changing Paint Finish - Painting - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 08:55 PM   #1
After priming and painting my study, I realize that I don't like the satin finish because I can see the wall-compound repairs. Can I use a flat-finish paint on top of the satin finish without having to prime again?
Bliss7777 is offline   Reply With Quote
Old 10-20-2009, 10:29 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Yes you can.
Old 10-20-2009, 10:32 PM   #3
Too Short? Cut it Again!
Originally Posted by Matthewt1970 View Post
Yes you can.
I agree.
Old 10-21-2009, 01:36 AM   #4
Rewards Points: 518
I found if you use a decent primer to begin with you'll blend the texture differences of the drywall surface and mud very well. I've used Sherwin Williams Qualikote high-hide latex primer and achieved this. I could not achieve this result with cheaper stuff from stores like Home Depot regardless of what sheen of paint I used. A second coat changing sheen helped but still will yield similar results unpleasing to the eye. You'll also be very disappointed with flat paint. It scuffs very easy and the only fix is usually a repaint. It is rarely washable as well.
n0c7 is offline   Reply With Quote
Old 10-21-2009, 06:23 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Or just put another coat of your satin on and the repairs should go away.
Old 10-21-2009, 07:52 AM   #6
Good quality flat latex is very washable and satin would not be a major improvement. Maybe when you get to eggshells and up in sheen to semis you pick up some ability to wipe them off---hence their preferred use in kitchens and baths. And I don't know what they did with the chemistry in Benjamin Moore Aura but the flat is amazing stuff. It is expensive but my clients---especially those with kids---really like it.
Old 10-21-2009, 12:15 PM   #7
Rewards Points: 518
Originally Posted by sdsester View Post
Good quality flat latex is very washable and satin would not be a major improvement. Maybe when you get to eggshells and up in sheen to semis you pick up some ability to wipe them off---hence there preferred use in kitchens and baths. And I don't know what they did with the chemistry in Benjamin Moore Aura but the flat is amazing stuff. It is expensive but my clients---especially those with kids---really like it.
Good to know. I've used Sherwin Williams and ICI Dulux flat's and both were a huge disappointment for durability and wash-ability.
Old 10-21-2009, 10:28 PM   #8
Some people just do not like shiney walls.
Old 10-21-2009, 10:57 PM   #9
Thanks so much for all your advice! I spent the better part of the day looking for a Benjamin Moore color in a rich red. The color I wanted, Heritage Red, is only available in exterior paint. They advised against using it inside because of the strong odor that can last a week. I remember using an exterior accent paint in the same room before, but I don't recall any problems with strong fumes. Is that really true? I went to Sherwin Williams and even to Home Depot to look at Ralph Lauren colors, but I ended up buying a Benjamin Moore Affinity color called Caliente. I was disappointed that all the red choices were either rosy, purplish, or leaning toward brick. The Heritage Red is a rich shade that is neither too bright nor too dusty. I've written Benjamin Moore with a request that they consider formulating Heritage Red for interiors. But as I think about it, I wish I had bought it anyway.
Old 10-21-2009, 10:59 PM   #10
And yes, I prefer flat or matte finishes. I find the gloss visually distracting. But I do like glossy on doors and trim.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Bathroom-need advice on changing paint types jmb324 Painting 9 01-23-2009 04:02 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
