Changing Color Or Pecky Cypress Paneling - Painting - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 10:41 PM   #1
changing color of pecky cypress paneling
My living room has pecky wood paneling going up to the vaulted ceiling. I am interested in changing the color from dated woodsy log cabin to rustic chic. The color is currently like http://floridacypress.com/About%20Cypress.htm and I would like it to look like http://www.limestoneandboxwoods.com/...om-nature.html Any suggestions?
Valerie1c is offline   Reply With Quote
Old 02-28-2012, 10:52 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 544
That is some beautiful wood, did you know the pecky wood was actually off fall or culled out of regular cypress. It is saved and sold as pecky and is higher priced than regular cypress. I guess you could get tired of looking at the same color for a long time, what color are you planning to paint/stain it? You aren't painting it white are you?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-28-2012, 10:59 PM   #3
I prefer not to paint at all, if I could stain that may be best. I just want the reddish brown color gone and have it look older like aged, whitish/gray- kinda like the color of driftwood.
The Following User Says Thank You to Valerie1c For This Useful Post:
BigJim (02-29-2012)
Old 02-28-2012, 11:03 PM   #4
Rewards Points: 626
OH MY GOSH! painting pecker wood cypress That is like drawing facial hair on the Mona Lisa or jazzing up a Rembrandt. That wood is so rare it cost a small fortune to have! to paint it or stain it should be a crime!
Nailbags is offline   Reply With Quote
Old 02-28-2012, 11:08 PM   #5
The room is big and the color is overwhelming. Makes it look dark and dreary.
Old 02-29-2012, 05:07 AM   #6
Val, in order to get to where you want to be, you have to know where you are now. Is your wood currently stained and clear coated?
Old 02-29-2012, 07:01 AM   #7
No it is not stained or clear coated.
Old 02-29-2012, 10:51 AM   #8
Rewards Points: 626
Instal lighting I bet there is not enough lighting for that room. Maybe some track lighting here and there?
Old 02-29-2012, 11:20 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 544
Now that would look awesome, the hard part will be to get that finish off the wood. One of the pros will be here soon and tell you how to work the magic.
Jim
Old 02-29-2012, 11:32 AM   #10
Rewards Points: 626
one of the ways is to weather it. let it get bleached by the sun or bleached chemically, and that I would be hesitant to try. one of the things about cedar wither it be western red cedar or cypress is it has Heavy Tannins in the wood giving it that dark red color. It serves two things it protects the tree from rot and decay from the weather and being eaten by bugs. It is also the source of that nice cedar smell. But like I said to get it to that gray it needs to be weathered or bleached thing to do is you might want to spot treat one little area with a bleach solution and see if that works?
Tags
painting woodwork , paneling , pecky cypress , wood staining
Wallpaper over paneling PPBART Painting 3 11-17-2011 10:35 PM
Stucco over my cedar wood paneling vs stucco over newly installed plywood beesan Building & Construction 5 12-21-2009 12:24 PM
uneven wood paneling joefromcal Carpentry 6 04-30-2009 09:50 PM
paneling replacement options tbinstl Remodeling 1 01-17-2009 08:44 AM
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 03:13 PM
